Oil pressure drop
#1 _Dimmo_
Posted 06 June 2019 - 07:14 PM
Posted 06 June 2019 - 09:30 PM
Loose oil pickup? Should have been fixed in place with a solid bracket off one of the mounting bolts, see 16min into video. Do you have any baffles or windage tray?
https://www.youtube....=youtu.be&t=846
Posted 06 June 2019 - 11:49 PM
Did you change the sump or oil pickup or the dipstick during the build? Could the oil level be too low even if the dipstick says it's okay?
When you say decelerating, do you mean heavy braking or just under engine braking? Does it make a difference if going uphill, downhill or level?
Posted 07 June 2019 - 12:25 AM
I used to have this problem in the 383 Holden when I drove it hard in the old sedan. After a couple of hard blasts up through the gears a big dig on the brakes would bring the oil pressure warning light on briefly. Solved by running a little extra in the HE sump.
Izzy from COME reckons this used to occur not infrequently in the yellow Torana at the end of the strip.
#5 _Dimmo_
Posted 07 June 2019 - 07:19 AM
#6 _Dimmo_
Posted 07 June 2019 - 07:22 AM
No mate same sump and dip stick combo. Just braking in general. But the harder the braking the quicker the pressure drop. Incline and decline whilst driving has no effect.
Posted 07 June 2019 - 08:40 PM
Engine/body earths good?Just braking in general. But the harder the braking the quicker the pressure drop.
Edited by rodomo, 07 June 2019 - 08:40 PM.
#8 _Dimmo_
Posted 07 June 2019 - 10:09 PM
It seems to be a carby issue dropping rpm during breaking
