Red 202 cam dailing
Red 202 cam timing stage 2
4 replies to this topic
#1 natcamp10
natcamp10
  • 113 posts
  • Name:Nathan
  • Car:Lj torana
Posted 14 June 2019 - 10:13 AM
Hi all
I trying to dial in a cam shaft on my red 202 and my cam spaces are as follows
Cm205d which is @50 217/217 vlift 429 dyurotech
The cam card I got says
Valve timing @.05 " cam lift
Inlet -1 Btdc opens and closes 38 abdc.. duration 217/217
SAE Valve timing @.006"
Inlet 30 BTDC AND CLOSES 70 abdc 280/280 duration
When I'm dailing in the cam I'm using a pushrods and lifter with a dail gauge setup on the push rod ..
My question is should I be using the SAE spec to time the cam ?
#2 LC-GTR-1969
LC-GTR-1969
    Shed tinkerer
  • 1,162 posts
  • Car:Which one?
Posted 14 June 2019 - 11:20 AM
Hi all
I'd use the timing events at .006 to dial in the cam. I would then check the degrees at .050 just for a sanity check that the cam is ground as it was advertised.
#3 dron
dron
  • 126 posts
  • Name:Darren
  • Car:UC
Posted 14 June 2019 - 07:27 PM
the last time I set up a cam I just used the how to guide that came with it. Some recomend using the start of lift inlet no1 and I have also worked on the max lift point inlet no1, The cam's that I have had gave me the deg that the cam should reach Xx th lift. The vidio below is a how to from the comp cam us site. I have not watched the full thing but it may help.
http://www.cpgnation...-camshaft.7553/
#4 natcamp10
natcamp10
  • 113 posts
  • Name:Nathan
  • Car:Lj torana
Posted 16 June 2019 - 07:25 PM
Hey
So it turned out to be SAE Timing , easy in the end 30” BTDC and 70” ABDC @.006 “ , keeping my bodgy degree wheel zeroed was my issue lol , got it in the end
#5 _NZ Toranaman_
_NZ Toranaman_
Posted 17 June 2019 - 04:51 PM
make sure you are using a solid lifter when do this as you can get incorrect reading on hydraulic.
find actual TDC first then the rest should be straight forward
