LH LX Rear Control Arms
7 replies to this topic
#1 _GMH-001_
_GMH-001_
Posted 10 July 2019 - 01:58 AM
Currently repairing/repainting an LH sedan for someone and when I removed the diff I noticed one of the lower control arms was installed wrong way round because the sway bar holes were towards the front of the car, easy fix. My question however is with the upper arms. Did GMH make 1 universal arm to fit left or right hand side. Been so long since my last torana I cant remember, that or age is showing more lol Correct me if I'm wrong but my final conclusion was they are universal because the front bushing is offset in the arm which would keep them true when mounted. Would just like to clarify this incase I am wrong, then I can notify the owner to organize replacement etc
    Cheers in advance for any help
#2 76lxhatch
  • 7,150 posts
Posted 10 July 2019 - 06:26 AM
You're correct, they're the same left and right
#3 Heath
  • 18,307 posts
Posted 10 July 2019 - 12:26 PM
As above.
#4 _GMH-001_
_GMH-001_
Posted 11 July 2019 - 03:38 AM
thankyou gentleman much appreciated. I had to confirm it as I have found a few arse about, half arsed and just completely wrong things during the process it wouldnt of surprised me if they were 2 L/H arms or something lol Especially with a lower arm mounted backwards. Anyway all good, cheers
#5 meanmachine72
meanmachine72
  • 2,005 posts
  • Name:Jono
Posted 11 July 2019 - 08:58 AM
whats the measurement between the arms when they are mounted?, iam after inside to inside control arm measurement
#6 UCSLE
UCSLE
  • 702 posts
  • Name:troy
  • Car:Goggomobil
Posted 11 July 2019 - 03:10 PM
its about this size between the arms :P
Attached File  diffsize.JPG   16.37K   0 downloads
#7 meanmachine72
meanmachine72
  • 2,005 posts
  • Name:Jono
Posted 11 July 2019 - 10:00 PM
lol thanks troy..
#8 _GMH-001_
_GMH-001_
Posted 13 July 2019 - 07:13 PM
Hey Johnno do you mean upper or lower arms or both, measured at chassis end of arms, diff end or middle of arms. I can take some measurements for you from chassis and diff (has had 9" fitted) but vehicle has had as many hits as elvis so I'd hate to give you measurements that turned out to be a few mm incorrect. However I cannot find any body damage forward of the diff its all been behind so it may be correct. Let me know if you're interested or you specifically need between arms themselves on vehicle
