Lc front brakes lock on.
19 replies to this topic
#1 evl666
evl666
  • 267 posts
  • Car:71 LC 73 LJ
Posted 19 July 2019 - 02:30 PM
Lc torana with a total rebuild. Overhauled calipers, new seals in the master cycling we and perfectly working brake booster. New lines as well. If I drive it for say a 5 minutes the brakes work fine but then if I drive it a bit long the front brakes start to lock on. I’ve adjusted the brake booster clearance and like I said it works fine till it gets drive a bit further than a few kms. Got me stumped
#2 Kevrev
Kevrev
  • 409 posts
  • Name:Kevin
  • Car:73 LJ GTR, 77 LX SS 253 Manual
Posted 19 July 2019 - 07:06 PM
You don't happen to have a 4 wheel drum brake master cylinder fitted by chance?
There's a residual pressure valve needed for drum brakes that keeps about 10lb of pressure in the line.
If there's one fitted to the front brakes it would cause the front brakes to lock on.
The valve is fitted under the brass seat that the brake line seals on.
https://www.freeases...heck-valve.html
#3 evl666
evl666
  • 267 posts
  • Car:71 LC 73 LJ
Posted 19 July 2019 - 09:37 PM
When the master got new seals and pistons I pulled the olive out out and made sure it was a disk/drum configuration. About after an hour after pulling up at home the brakes have unlocked. They weren’t totally locked on but really tight.....just managed to push it by hand in the garage
Edited by evl666, 19 July 2019 - 09:39 PM.
#4 LJ RB30
LJ RB30
  • 974 posts
  • Name:Trevor
Posted 21 July 2019 - 12:43 AM
When they are locked on pull  the vacuum line out of the booster & see if they release.
#5 DMLC71
DMLC71
  • 424 posts
  • Name:Daz M
  • Car:1971 LC 4 door
Posted 21 July 2019 - 08:12 AM
Might be an idea to see if the booster push rod is the correct length
#6 S pack
  • 15,538 posts
Posted 21 July 2019 - 08:57 AM
Were the calipers with new pads fitted a very neat fit over the rotors?
#7 liswar2
liswar2
  • 1,482 posts
  • Name:Wazza
Posted 21 July 2019 - 07:48 PM
Booster push rod , was my problem in the past with a rebuild , as there is a difference between lc and lj length ,
Depends on which you have ,
My brakes did the same thing , so swapped the shorter push rod for the longer version , problem solved ,
Yes big nut master cyl and double diaphragm booster.
#8 holdentoranaman
holdentoranaman
  • 113 posts
Posted 22 July 2019 - 12:39 AM
same thing happened after paying reputable person to rebuild big nut master .apparently a bad batch of seals requiring push rod to e slightly shorter to clear port.when it happens loosen 2 nuts holding master cylinder to booster to see if thats the problem.
#9 evl666
evl666
  • 267 posts
  • Car:71 LC 73 LJ
Posted 27 July 2019 - 04:02 PM
Sorry guys....I’ve been busy but haven’t had a chance to touch the car. At the time I unscrewed the master from the booster and it made no difference so it’s not the push rod length. Yes the pads and discs are new and were a tight fit but still spin freely when cold. I’m going to take it out for a short drive and see if I can get to to lock on then have another fiddle.
#10 Potta
Posted 28 July 2019 - 11:57 PM
Mine was like this when I got it to the point where I could push it forwards but not backwards.
A caliper rebuild fixed it for me. The pistons weren't going back in the bores properly.
#11 evl666
evl666
  • 267 posts
  • Car:71 LC 73 LJ
Posted 29 July 2019 - 12:27 PM
That’s what I’m thinking Potter. Was going to pull the brake calipers off and wack some new pistons in there and try again. I’ve already put a new seal kit through them
#12 Potta
Posted 30 July 2019 - 09:20 PM
Need to let them soak in metho, give the bores a gentle rub if there is any pitting or rust, and also use a liberal amount of rubber grease when you put them all together.
That's what Dattoman told me and it seemed to work quite well.
#13 evl666
evl666
  • 267 posts
  • Car:71 LC 73 LJ
Posted 02 August 2019 - 07:09 PM
Question...just want to check something while I’ve got the calipers apart....the seal that sits inside the piston bore of the calipers is that tapered and goes in a certain way or is it my imagination?
#14 rodomo
  • 17,999 posts
Posted 02 August 2019 - 09:37 PM
The annular groove that it sits in is is tapered. The seal itself is square section...…………….if my memory is correct?
#15 evl666
evl666
  • 267 posts
  • Car:71 LC 73 LJ
Posted 03 August 2019 - 03:22 AM
Thanks rondomo. I’ll finish rebuilding the calipers and fitting new flexible lines today and see how we go
#16 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 04 August 2019 - 05:18 PM
Verniers might help you determine that, or pm or ask datto aswell maybe ?
#17 evl666
evl666
  • 267 posts
  • Car:71 LC 73 LJ
Posted 18 August 2019 - 06:03 PM
Ok guys....so rebuilt the calipers again this time with new pistons and put new flexible lines. Took it for a drive did the same thing again. Cracked the nut where the front brake line goes into the master cylinder and she was still under pressure so it had to be the master. I grabbed a new master I had and threw it on...low and behold it works perfectly fine. Grabbed the the big nut master, striped it down and it looks like the tiny hole in the front port was blocked solid. So it a like when the heat caused everything to expand the fluid couldn’t flow back into the master causing the pressure to build up
#18 RallyRed
  • 7,841 posts
Posted 18 August 2019 - 06:17 PM
good feedback mate..and good find too.
#19 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 18 August 2019 - 06:40 PM
Great result mate ! Gary.
#20 liswar2
liswar2
  • 1,482 posts
  • Name:Wazza
Posted 20 August 2019 - 03:21 PM
Good to know for the future , just in case ,
Great detective work agent 86
