Aussie 4 speed red paint KBS Motor Coater, new product
M20 M21 paint
6 replies to this topic
#1 jd lj
jd lj
  • 2,100 posts
  • Name:James D
  • Car:LJ SVO
Posted 25 July 2019 - 07:13 PM
Hi guy's,
At the start of this year I was swapping gearboxes and wanted to give the new one a coat of paint in the correct colour. I contacted KBS COATINGS and took a original m20/m21 side plate down to see what they had available in their "Motor Coater" range as I wanted to use a good quality paint and I've always had good results with their products. At the time none of the colours were a close enough match, so I purchased two of the existing colours and did my own mix to get the correct colour. This turned out well.
I sprayed a sample and gave that to the friendly staff at KBS COATINGS and discussed the demand for such a product.
Fast forward 6 months or so and now you can all buy the "Aussie 4 speed red" online through KBS COATINGS or their stockists. The Motor Coater range of paints is heat and chemical resist and tough as nails.
Here's the link...
https://www.kbs-coat...t/motor-coater/
James D
#2 jd lj
jd lj
  • 2,100 posts
  • Name:James D
  • Car:LJ SVO
Posted 25 July 2019 - 07:41 PM
I should add that I was given a sample card sprayed with the new product and the KBS team have done a great job of matching the colour.
#3 hanra
  • 10,832 posts
Posted 25 July 2019 - 08:48 PM
I found the white knight red oxide primer was almost bang on.
#4 hanra
  • 10,832 posts
Posted 25 July 2019 - 09:19 PM
#5 jd lj
jd lj
  • 2,100 posts
  • Name:James D
  • Car:LJ SVO
Posted 26 July 2019 - 05:35 AM
Your colour match doesn't look too bad there Brad, I think that the KBS is atleast as good of a colour match if not better though and to compare the primer to the Motor Coater paint is comparing two very different products.
#6 Dr Terry
Dr Terry
  • 3,276 posts
Posted 27 July 2019 - 08:40 AM
Isn't this colour the same as EH-HR engines & HK-HG steering box lids ?
If not it's very close.
Dr Terry
#7 jd lj
jd lj
  • 2,100 posts
  • Name:James D
  • Car:LJ SVO
Posted 27 July 2019 - 01:38 PM
Dr Terry
That's the colour that I was going to originally buy from the KBS range but the sample was too dark.
