Koni rear shocks bottoming out
#1 _stocaz78_
Posted 28 July 2019 - 06:40 PM
My rear shocks are bottoming out, is there a shock I can buy with less travel?
Posted 28 July 2019 - 07:16 PM
Posted 28 July 2019 - 07:24 PM
Have you check travel lengths vs bump stops?
Is it hitting bumpstops first?
Posted 28 July 2019 - 07:31 PM
Bump stops fitted? Correct PN shock for the vehicle?
I seem to remember Koni doing shorter shocks for lowered cars, but its more about the spring not falling out at full shock extension rather than then bottoming out, or at least that's what I believe the main issue is.
#5 _stocaz78_
Posted 28 July 2019 - 08:23 PM
I'm 100% sure it's the shock bottoming out
Posted 28 July 2019 - 08:49 PM
They make them for a reason you know?
Posted 28 July 2019 - 10:01 PM
Posted 28 July 2019 - 11:11 PM
Without bump stops it is probable that you have smashed the guts out of the shocks. They are there for a reason as someone said earlier. Koni also fit shaft bump stops to their shocks to avoid this issue, however if the car is lowered and shocks were not ordered with this mention I reckon they are knackered for sure. I run a full Group NC suspension package on my LJ XU1, which includes lowered springs etc and I know the Konis that are part of this package have shorter shafts amongst other changes. My bump stops are "reduced" in height but still present, have never had a bottom out .
