Tailshaft Lengths
14 replies to this topic
#1 blown308
blown308
  • 2,328 posts
Posted 06 August 2019 - 08:51 AM
Can some please let me know the tail shaft lengths  for LJ and LH
We have 7 tail shafts here and don't know which one suits the LJ
Image is attached
Wayne
#2 jd lj
jd lj
  • 2,100 posts
  • Name:James D
  • Car:LJ SVO
Posted 06 August 2019 - 09:08 AM
IIRC, the LJ tailshaft is 1240mm between the middle of each uni joint. For a w50 Celica gearbox in a LJ it's 1210 to 1215mm. I hope that helps.
#3 Bigfella237
  • 4,373 posts
Posted 06 August 2019 - 12:25 PM
I had 48.74" (1238mm) for a 6 cylinder LJ but we won't argue over 2mm. :P
I also have noted:
LH/LX 6 cyl shaft = 50.25" (1276mm) long x 2.5" (63.5mm) diameter
LH/LX V8 shaft = 49.95" (1269mm) long x 2.5" (63.5mm) diameter for 4.2L or 2.75" (69.85mm) diameter for 5.0L
And from the parts catalogs:
GOLD = all 4 cyl Exc/Torquemaster
VOILET = 4 cyl w/Torquemaster
BLACK = all 6 cyl Exc/LHD
ORANGE = Left Hand Drive 6 cyl 3 speed manual only
LIGHT GREEN = all 4.2L V8s
RUST BROWN = all 5.0L V8s Exc/A9X
Edited by Bigfella237, 06 August 2019 - 12:27 PM.
#4 hanra
  • 10,832 posts
Posted 06 August 2019 - 12:34 PM
Im yet to have seen a Rust Brown tail shaft.
#5 Indy Orange
Indy Orange
  • 2,848 posts
  • Name:Paul
Posted 06 August 2019 - 02:02 PM
Grey are LCGTR.
#6 S pack
  • 15,538 posts
Posted 06 August 2019 - 02:30 PM
The 3 shorter shafts with the red paint should be LJ 6cyl
#7 Dr Terry
Dr Terry
  • 3,276 posts
Posted 06 August 2019 - 02:36 PM
Grey are LCGTR.
Yes, any LC 6-cyl with an M20 Opel 4-sp has the Grey tailshaft.
Dr Terry
#8 Indy Orange
Indy Orange
  • 2,848 posts
  • Name:Paul
Posted 06 August 2019 - 02:47 PM
Unless it's a later LCGTR with the Aussie M20 ,then I think it was red.
#9 arrimar
arrimar
  • 3,122 posts
Posted 06 August 2019 - 06:03 PM
Here's two.
#10 Dr Terry
Dr Terry
  • 3,276 posts
Posted 07 August 2019 - 11:28 AM
Yes, red shaft for LC/LJ with M20 Aussie box, M15 & M40.
Dr Terry
#11 hanra
  • 10,832 posts
Posted 07 August 2019 - 11:36 AM
Here's two.
Are they on an L34?
#12 arrimar
arrimar
  • 3,122 posts
Posted 07 August 2019 - 01:03 PM
The top one is my L34 and the bottom is my LH SL/R 5000.
#13 hanra
  • 10,832 posts
Posted 07 August 2019 - 01:47 PM
Interesting. I always thought the stepped tail shaft was only on the L34. Not often you see them available for sale.
#14 arrimar
arrimar
  • 3,122 posts
Posted 07 August 2019 - 03:37 PM
No. A cut down ute one would look similar but not the same length of skinny section or diameter IIRC.
#15 arrimar
arrimar
  • 3,122 posts
Posted 07 August 2019 - 04:35 PM
What I meant is, no, you don't often see them for sale.
