Hey guys. just wondering if it would be possible to run a dry sump system on an auto trans? looking at running a dry sump kit on the engine and thought, why not run one on the trans. Just throwing around ideas to lower the motor and trans for better center of gravity. Plus would help with trans temps. Thanks
Wet sump th400?
_dazzatheman_
, Aug 20 2019 10:59 AM
2 replies to this topic
#1 _dazzatheman_
Posted 20 August 2019 - 10:59 AM
Posted 20 August 2019 - 12:32 PM
Anything's possible but there's not much clearance on a standard pan (deep pan adds a bit), so you wouldn't gain much if lowering the trans is your only aim.
Posted 20 August 2019 - 12:37 PM
Might need to look at a dry sump flex plate while you’re at it...............
