G'day guys and gals. I dragged my roof lining rods down out of storage today and realised I think one is missing. The set that came with car has 1 long, 2 short and two sections of twisted thin wire (not sure what relevance if any they have). I presume one of the rods is missing, but not sure what length it is. I searched other threads on this forum and it appears 2 door rods are different from 4 door. Does anyone know which rod is missing from my set as I hope to bend/shape one up from same thickness wire, or have a photo of a 2door set so I can "guesstimate" what length rod I need to make. Also what sequence do they go from front to back and which 2 holes do they slot into (ie top or lower of two along roof rails/pillars). I checked manuals but they don't seem to cover roof linings. Thanks in advance, Paul
LC/LJ door door roof lining rods
Posted 20 August 2019 - 09:14 PM
Posted 21 August 2019 - 01:26 PM
Posted 21 August 2019 - 04:12 PM
Thanks limo, yes two smaller ones are same length, if you could measure a set that would be ace, thanks paul
Posted 21 August 2019 - 05:32 PM
Hi Paul,
if you get stuck I have a set still in the hood lining but out of the car I can photograph and measure.
Marty
Posted 21 August 2019 - 07:42 PM
Marty, very generous of you, I appreciate that, ill see what limo comes back with, also do they go in lower or upper hole locations and do you know what sequence, thanks again paul
Posted 21 August 2019 - 08:34 PM
Posted 22 August 2019 - 04:57 PM
IMAG0952 (2).jpg 152.68K
9 downloads
IMAG0951 (2).jpg 155.36K
7 downloads
I think they go in order shown front to back
couldn't find tape so pics
different shape ends,
first 2 same length third one is longer by about 10 mm
if you are making one really need one to copy
Posted 22 August 2019 - 09:36 PM
Thanks limo, its a good start. Marty if I could impose on you to photograph and measure the ones you have it might give me something to work with in making the missing rod from the set, seeing as I wont have one to compare to or trace off. Thanks for helping a brother out in advance, paul
Posted 23 August 2019 - 10:30 AM
Rod lengths from front to back
1040mm x2
1050mm
1185mm
IMG_8513.jpg 189.1K
11 downloads
Heres a few pics I took before removal. Letter P means passenger and numbers start from front.
Good luck
Marty
IMG_7981.jpg 142.6K
11 downloads
IMG_7986.jpg 173.46K
8 downloads
IMG_7979.jpg 58.94K
7 downloads
IMG_7980.jpg 48.97K
5 downloads
IMG_7983.jpg 141.17K
8 downloads
IMG_7984.jpg 48.82K
5 downloads
IMG_7985.jpg 143.7K
7 downloads
Posted 23 August 2019 - 01:18 PM
Hi
From the workshop manual
Bazza
Posted 23 August 2019 - 02:13 PM
Marty, Bazza, Lima, you are the man! thanks heaps, I keep you posted how I go but think I've got it from here! Thanks again guys.
Posted 23 August 2019 - 02:59 PM
_macdou_
Posted 23 August 2019 - 04:43 PM
2 door bows are all different lengths, 4 door have 3 different lengths with the 2 in the middle are the same.
I would assume workshop manual is correct....
What are the 4 lengths of the 2 door bows?
Hi
Bazza
Posted 23 August 2019 - 06:34 PM
Posted 08 September 2019 - 08:25 PM
Marty ,interested to know if there was any underlay material between the rods and roof ?Ta Paul.
No.
Only under roof lining around rear quarters.
Marty
Posted 08 September 2019 - 08:31 PM
_torana38_
Posted 17 December 2019 - 10:56 AM
This is great but where do the clips go
Posted 17 December 2019 - 01:46 PM
Posted 17 December 2019 - 01:49 PM
Posted 18 December 2019 - 07:27 PM
#21
Posted 19 October 2020 - 11:16 AM
so did all rods have those clips?
#22
Posted 19 October 2020 - 07:35 PM
#23
Posted 19 October 2020 - 09:11 PM
lol yet to look. but my 2 middle hops got clips on them. seem to remember my bros car hoop flipping over and that was a LC
#24
Posted 19 October 2020 - 09:37 PM
