Best type of Valve Spring compressor for Holden 6 (202) ?
10 replies to this topic
#1 Com_VC
Com_VC
  • 411 posts
Posted 27 August 2019 - 07:19 PM
Hi all,
Need to remove some valves from a 202 12 port head, just wondering what the best type of valve spring compressor to use to get them off easily.  Head is not currently on the engine.  It has double valve springs as well, so may be a little harder to get off.
#2 Com_VC
Com_VC
  • 411 posts
Posted 03 September 2019 - 12:17 PM
Anyone know of anything? Even something homemade?
#3 koalasprint
koalasprint
  • 295 posts
  • Name:Steve
  • Car:LX SS Hatch
Posted 03 September 2019 - 12:36 PM
I have one of these. It works with double valve springs but can be fiddly, needs to be in the right spot to work. It is slow compared to other designs. But I got the job done.
https://www.ebay.com...&frcectupt=true
#4 LC-GTR-1969
LC-GTR-1969
    Shed tinkerer
  • 1,162 posts
  • Car:Which one?
Posted 03 September 2019 - 05:41 PM
The basic old style work great;
https://www.superche...ssor/12555.html
I have an older style one but it can whip out valve springs and valves in no time
#5 Com_VC
Com_VC
  • 411 posts
Posted 03 September 2019 - 08:34 PM
I already had a similar valve spring compressor to that supercheap one, the last time I tried it I couldn't get the lever to compress so gave up thinking it was the wrong type, so today I used a 300mm pipe on the end of it for some leverage and it worked easily :)
#6 rodomo
  • 17,999 posts
Posted 03 September 2019 - 10:02 PM
Because the collets are wedge shaped, they jam in. Put a bit of tension on it then give the valve cap a hit with a soft faced hammer. You only need 3 hands.
#7 S pack
  • 15,539 posts
Posted 04 September 2019 - 07:52 AM
The beauty of simplicity.
#8 Com_VC
Com_VC
  • 411 posts
Posted 15 September 2019 - 09:43 AM
Seems to work easier using a socket over the valve spring retainer cap
#9 fuzzypumper
fuzzypumper
  • 929 posts
  • Name:Archie
Posted 15 September 2019 - 08:09 PM
I also made one many moons ago using a VC commodore front bumper iron.
#10 sr2
sr2
  • 31 posts
  • Name:Butler Simon
  • Car:186 X2 Powered Rigamortice (1947)
Posted 08 October 2019 - 08:18 PM
Build your own using an old C Clamp.
Link is to my car rebuild thread on Oldschool NZ, scroll to the bottom for pictures.
https://oldschool.co...-thread/page/3/
#11 klevliend
klevliend
  • 43 posts
Posted 05 November 2019 - 11:58 AM
I made a very simple valve spring compresser at home DIY thats working great for me recently. Cost less than $25 in parts from bunnings. Pretty much just a post anchor and 15mm galvanised plumbing piping with a 'T' piece and some bolts to tie it together. The two brackets bolted through the piping that push down on the valve could be improved on though, just by using something thicker and stronger. Also maybe turning the post anchor around the other way would put less stress on the bolts holding it to the wood? But this works fine for me :)
