are transbrakes available for holden 6 trimatics.
transbrake
_lawn bowls_
Posted 08 September 2019 - 02:57 PM
Posted 08 September 2019 - 08:02 PM
I think "Performance Transmission Components" in Victoria do them, seem popular with the 4cyl turbo Gemini's!
_lawn bowls_
Posted 12 September 2019 - 02:08 PM
yes they do have transbrake to suit 6 cylinder trimatic but don’t sell them seperately they do put them a n there built 6 cylinder trimatic for about $4500.same as Hugo from race glides he has them also but won’t sell him seperatley his 6 cylinder trimatic with trans brake is $3450I think "Performance Transmission Components" in Victoria do them, seem popular with the 4cyl turbo Gemini's!
Posted 12 September 2019 - 07:54 PM
I guess there are quite a few mods to the trans being the reason. Back in the day VL turbos were breaking trans braked Trimatics which is why other transmissions are now more popular.
You could still build boost of the line with a good converter, manual valve body (using 2nd gear), 2 step rev limiter, well adjusted brakes.
_lawn bowls_
Posted 12 September 2019 - 07:58 PM
yeah but the problem is I thought the transbrake where ready available but finding it hard to find one by it self I brought a 4000 rpm slingshot 8 inch converter to suit transbrake.maybe I should not have brought itI guess there are quite a few mods to the trans being the reason. Back in the day VL turbos were breaking trans braked Trimatics which is why other transmissions are now more popular.
Posted 13 September 2019 - 06:09 PM
Not ideal then, will have to decide which way to go with either paying the price for a built transbrake Trimatic or having the converter adjusted for non transbrake use.
_lawn bowls_
Posted 13 September 2019 - 06:39 PM
trans shop told me they can make a trans brake with solinoid and switch for $1100 sounds good as I already have a built trimatic and 4000 rpm 8 inch slingshot hi stall converter to suit trans brake it came out of a 11 second turbo 202 in a lc torana with a poor mans lenco lolNot ideal then, will have to decide which way to go with either paying the price for a built transbrake Trimatic or having the converter adjusted for non transbrake use.
Posted 13 September 2019 - 10:00 PM
That's good news, price does not sound half bad either. I'm guessing it will be reverse shift pattern and the loss of engine braking?
_lawn bowls_
Posted 13 September 2019 - 10:09 PM
yeah not sure if it’s going to be reversed shift pattern I would prefer to be forward shift but if not it doesn’t matterThat's good news, price does not sound half bad either. I'm guessing it will be reverse shift pattern and the loss of engine braking?
_lawn bowls_
Posted 14 September 2019 - 03:22 PM
what grade of fluid does the 6 cylinder power glide converter takesyeah not sure if it’s going to be reversed shift pattern I would prefer to be forward shift but if not it doesn’t matter
Posted 14 September 2019 - 06:38 PM
Usually its Dexron III same as the Trimatic.
_Drag lc_
Posted 15 September 2019 - 07:26 AM
those prices around 4k sound about right for a t braked tri unfortunately good tris are not cheap and there is a fair amount of work to do it properly inside the trans.
if your at the level of needing one that 4k price should not scare you at all.
not sure if you've used one before but the rest of the driveline needs to up to spec aswell.
Posted 17 September 2019 - 12:19 AM
to take about 600hp through it .was 9 yr ago but ..
Edited by madtoranajzedded, 17 September 2019 - 12:21 AM.
