lx lh torana accelerator pedal mounting diagram
23 replies to this topic
#1 jonesy
jonesy
  • 637 posts
  • Car:hatch
Posted 10 September 2019 - 09:02 PM
hey tnuts,
need a fav
went to do a little more work on the hatch today and i have miss placed my workshop manual,
can some one out there post up the diagram for the automatic pedal mounting assembly
spent more time looking for the manual; than it would take to put together ... shts me
lx hatch
cheers guys
#2 hanra
  • 11,033 posts
Posted 10 September 2019 - 09:10 PM
https://1drv.ms/b/s!...x0uCmnYRBAXA2sQ
https://1drv.ms/b/s!...jX6yg20Y7KUwAtJ
#3 jonesy
jonesy
  • 637 posts
  • Car:hatch
Posted 10 September 2019 - 09:43 PM
bugger on the work comp...cant get on the shared sites to see this but thanks anyway i will look when i get home tomorrow morn..
cheers brad
#4 Shiney005
  • 9,824 posts
Posted 10 September 2019 - 11:27 PM
I thought I could screenshot the picture and put it up, but my internet is running that slow tonight it would be faster to chisel it into a stone tablet and have 100 carrier pigeons drag it to you.
Is LH and LX the same? I can get my LH one out of the shed in the morning.
#5 jonesy
jonesy
  • 637 posts
  • Car:hatch
Posted 11 September 2019 - 12:01 AM
i would appreciate any that could help with this and i am under the impression they are the same,
cheers lads
#6 S pack
  • 15,762 posts
Posted 11 September 2019 - 12:50 AM
From the LH Workshop Manual.
#7 jonesy
jonesy
  • 637 posts
  • Car:hatch
Posted 11 September 2019 - 02:24 AM
perfect exactly what i need thanks to all that replied
#8 Shiney005
  • 9,824 posts
Posted 11 September 2019 - 10:20 AM
I don't want to give away too much here, but there are a couple of different Pedal Lever and Pivot assemblies. It shouldn't affect you Jonesy unless you have another car in the shed you aren't telling us about.
#9 308mate
308mate
  • 523 posts
  • Name:scott
  • Car:76 SS hatch (Royal Plum, Chevron Chamois interior), HQish Van (Orchid Metallic)
Posted 11 September 2019 - 07:22 PM
What’s the go with the different mounts for L6 and V8?
#10 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 11 September 2019 - 07:46 PM
The pedals are different between 6 and v8. The pivot point is moved so the v8 cable has more travel and hence why the bracket on the floor has 2 holes so the pedal is in the same spot.
#11 Cook
Cook
  • 1,534 posts
Posted 11 September 2019 - 08:04 PM
Same as the different clutch pedal points between 6 & 8cyl for my WB.  Cheers Ron
#12 yel327
  • 13,783 posts
Posted 11 September 2019 - 09:22 PM
And the clutch pedal itself, but not just WB, HZ from mid 1978 too. I think Commodore is the same as well.
#13 jonesy
jonesy
  • 637 posts
  • Car:hatch
Posted 12 September 2019 - 12:07 AM
hahha cant really afford any more regos with the current projects and cars
#14 308mate
308mate
  • 523 posts
  • Name:scott
Posted 12 September 2019 - 07:33 PM
Anyone got a 6 and v8 pedal and could take a photo toget?
#15 hanra
  • 11,033 posts
Posted 15 September 2019 - 08:31 PM
LX Hatch 6cyl Auto accl pedal
#16 308mate
308mate
  • 523 posts
  • Name:scott
Posted 22 September 2019 - 08:02 PM
Attached File  IMG_0941.jpg   124.15K   4 downloads
Heres the pedal from my hatch. It was a factory 6. Looks the same as yours Hanra.
#17 Cook
Cook
  • 1,534 posts
Posted 23 September 2019 - 09:34 AM
Here are the 2 pedals I have.  The one on the left is, I believe from a H series car.  The one on the right I think/hope is a Torana one.  I note that it is slightly different to yours Scott (or maybe it's just the camera angle).  According to the parts catalogue, if I'm reading it right there is a different part # for the 8cyl pedal than the 4 & 6's but I haven't been able to find anything about this.  I also noted that the kickdown bracket for the H series is different from the Torana one (which I am trying to source at present).  Cheers Ron
#18 yel327
  • 13,783 posts
Posted 23 September 2019 - 10:45 AM
I’ll check HJ-WB catalogues for you tonight to see if a Holden used different throttle pedals for 6cyl and V8. It is obvious Torana does so it makes sense that a Holden would too as the required cable movement at the carby shouldn’t change between Holden and Torana, I know the V8 carbs and the cable attachment is the same between them, I assume 6cyl is too.
#19 Cook
Cook
  • 1,534 posts
Posted 23 September 2019 - 01:25 PM
I didn't think to look at my WB parts catalogue until you mentioned it yel327.  It shows different part numbers for 6 (#9933550) & 8cyl (#9933549).  I wonder what they look like.  FWIW the part # for the LX are 4 & 6cyl (#9933378) & 8cyl (#9933483). Cheers Ron
#20 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 23 September 2019 - 01:50 PM
6cyl and v8 torana pedal comparison
Attached File  22730311_10214139710148274_2923252555768501404_n.jpg   10.26K   9 downloads
#21 Cook
Cook
  • 1,534 posts
Posted 23 September 2019 - 01:58 PM
Toranamat69 that's awesome.  Do you have any idea of the different lengths from the top to the pivot point?  Cheers Ron
#22 308mate
308mate
  • 523 posts
  • Name:scott
Posted 23 September 2019 - 07:23 PM
Thanks for the input there fellas. The comparison shot is awesome Toranamat.
I’ll have to check that I’m getting full throttle when the engine is in. I’m running a Holley ultra HP...
#23 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 13 October 2019 - 05:18 PM
Gday Ron sorry i took a bit i had to dig the pedals out of the parts shed. That photo is a few years old.
Anyway as best as i can measure, the 6 cylinder pedal is 160mm from centre of pivot to top of bracket and the V8 pedal is 183mm.
Matt
#24 Cook
Cook
  • 1,534 posts
Posted 14 October 2019 - 09:08 AM
Thanks Toranamat.  If I had of thought (hard for me sometimes lol) I guess it's the same measurement as between the different bolt holes in the firewall bracket.  Thanks again. Ron
