Lc fitting carpet around front seat legs
10 replies to this topic
#1 _brett1022_
_brett1022_
Posted 18 September 2019 - 10:23 PM
Hi , I found out recently that LC front seats bolt directly to the floor pan and not on top of the carpet like most I've seen. I need to fit carpet soon ,but for all my internet digging I can't find any pics that show how it should be done. Can anyone help please ? Thanks
#2 Potta
Posted 19 September 2019 - 02:07 AM
You will need to cut the carpet on 3 sides so you can put the bolt in and then there is a little carpet tab that folds back over the top.
I'm not sure which side should be left uncut, but it may be self evident once you have a look at it.
#3 _brett1022_
_brett1022_
Posted 19 September 2019 - 12:35 PM
No worries, thanks for that. I'll need to keep searching for a pic to see what side to cut I reckon. Want to get it right.
#4 Indy Orange
Indy Orange
  • 2,846 posts
  • Name:Paul
Posted 19 September 2019 - 07:49 PM
Can't find anything either Brett ,thought about cutting a "U" shape so that the carpet flap fits back inside the seat mount.
#5 _TREV TORRI_
_TREV TORRI_
Posted 30 September 2019 - 10:07 PM
Hi Brett, were you able to find out the correct way to cut carpet for the front seats, im getting close to needing to to do this aswell
#6 RallyRed
  • 7,836 posts
Posted 01 October 2019 - 07:53 AM
Hi ..12/70 LC GTR...only pics I have of this area..hope they help.
Col
#7 _brett1022_
_brett1022_
Posted 01 October 2019 - 08:12 AM
I haven't found any clear info yet,my friend picked up a lc gtr last weekend and it has slots cut in the front carpet so there's a flap that goes into the gap in the leg , if that makes sense, looks a bit rough though.Not convinced that it's factory done.
#8 RallyRed
  • 7,836 posts
Posted 01 October 2019 - 08:16 AM
yes, there are slots. And yes, from factory the are not perfect at all.
#9 _brett1022_
_brett1022_
Posted 12 October 2019 - 07:54 PM
So I sat the seats where they needed to go on top of the carpet and then traced around the feet with chalk. Then took the seat away and cut basically an "H" SHAPE where the leg sat . Then folded the flaps back and sat the seats on the floor pan.Worked out perfectly.
#10 _TREV TORRI_
_TREV TORRI_
Posted 14 October 2019 - 03:55 PM
Any pics please Brett. What underlay and thickness did you use ?
#11 _brett1022_
_brett1022_
Posted 22 October 2019 - 08:31 PM
I didn't take any while I was doing it but I just used the underlay that came with the carpet from Knox, bought as a Set
