I need a nipple
8 replies to this topic
#1 _macdou_
_macdou_
Posted 23 September 2019 - 10:02 AM
Hi chasing a few of these fittings if anyone has some for sale
Alternatively somewhere I could buy some
They are a fitting for a HD type SU Fuel bowl
#2 _macdou_
_macdou_
Posted 23 September 2019 - 10:09 AM
I also need this over flow fitting and bolt if someone has one or more
#3 VIXL34s
VIXL34s
  • 177 posts
  • Name:jeff
  • Car:2x L34s,+ HZ GTS, A9X HATCH.A9X SEDAN
Posted 23 September 2019 - 10:18 AM
Don’t we all
#4 yel327
  • 13,009 posts
Posted 23 September 2019 - 10:53 AM
Did all SU’s have the same fittings? There used to be a wrecker here that had shelves full of stuff off old Pommy cars that had SU’s standard, but I don’t think they are around anymore. I remember seeing dozens of old SU carbs off old Rovers, I only noticed as I had a triple SU carb setup on my old HQ Van and recognised the carbs. Might be worth looking to see if there are any older wreckers near to you. There are a couple of specialist Rover wreckers around. All 4x4 in Hunter Valley started as a Landrover wrecker in the 80’s so they may still have old SU’s?
#5 Cook
Cook
  • 1,497 posts
Posted 23 September 2019 - 01:35 PM
I was just googling this out of interest and came across a bus called recarb in QLD that advertise a fuel spout banjo union, which is not exactly the same as your pic but very similar.  They may be an option.  Good luck. Ron
#6 VIXL34s
VIXL34s
  • 177 posts
  • Name:jeff
Posted 23 September 2019 - 02:13 PM
You should be able to get those type of fittings from a diesel repair type service
#7 I'm a Red Motor fiend
  • 758 posts
  • Name:Adam
  • Car:LJ 4 door, LC GTR
Posted 24 September 2019 - 01:24 PM
There are banjos and overflow tubes on eBay or I would imagine SU Midel would have them.
#8 _Lazarus_
_Lazarus_
Posted 25 September 2019 - 05:54 AM
I believe Gladys, the 1956 model mechanical Sexbot from British Aerospace had nipples like that.
#9 caterham2
caterham2
  • 348 posts
  • Location:Mansfield North East Victoria not the other one in QLD
  • Car:Ford Focus RS AWD Gone over to the dark side .. Mercedes-Benz SLK350 Ford Cortina 2 door MK1 Twin Cam
Posted 25 September 2019 - 11:01 PM
Forget Gladys, you need to talk to Midel in NSW. They have absolutely everything for SU carbs. If they have not got it they will make it, including custom needles etc. Been able to get everything for my HD8 carbs easily.They are part of Fabre Australia
