Proforged or Moog
1 reply to this topic
#1 308mate
308mate
  • 498 posts
  • Name:scott
  • Car:76 SS hatch (Royal Plum, Chevron Chamois interior), HQish Van (Orchid Metallic)
Posted 28 September 2019 - 09:04 AM
Just wondering if anyone has used the adjustable proforged ball joints? Just about to put my k frame together after blasting and painting and I’ve got bot on the shelf.
I’m using lx kframe with higher mounting points for the upper arms, UC upper arms, hq spindles and harrop steering arms.
I’ve never even opened the proforged box so I’m not even sure how the proforged adjust...I guess I have to check them out when I get home.
#2 ozyozyozy
ozyozyozy
  • 850 posts
Posted 30 September 2019 - 12:45 AM
Dont know the proforged but the howe ones are quite simple to adjust.
If they are similar to howe they have a locking grub screw and a screw insert that can be wound in and out to adjust tension of the ball.
Savy motorsport do height adjustable ball joints, they swap out the insert to raise or lower the distance between stub axle and ball joint pivot point.
