ill be buying engine bearings very soon i can only find acl and king bearings.is there any difference between the race series and the normal bearings.it needs to suit boost for a 186
engine bearings
Posted 03 October 2019 - 03:03 AM
Posted 03 October 2019 - 10:32 AM
I can remember a time a while back when a good engine builder i was talking to said he recommended ACL race series to everyone he did machining work for.
I didnt get into the ifs and buts and whatnots with him at the time, but everything else he talked about was spot on information.
Not sure if this helps you exactly though.
But I guess a lot of it will come down to the boost pressure you will be dialling in, especially with head gaskets.
Sounds like you have your mind set on a decent combo.
Rob
Posted 03 October 2019 - 11:26 AM
Is Myers doing all your machine work?
Posted 03 October 2019 - 12:07 PM
Interesting as my engine machinist said something similar. I normally use KING bearings but on the current 355 I am building for a V3 supercharger I have gone with his recommendations and am fitting ACL.
Rob
Posted 03 October 2019 - 02:32 PM
either myers or hm gem
Posted 06 October 2019 - 11:34 AM
For my Hi-po (aspirated) 355 i asked my machinist who has some big runs on the board the same question. He said "race series, the std ones wont last."
Posted 07 October 2019 - 07:44 PM
Posted 19 October 2019 - 08:32 AM
Posted 19 October 2019 - 01:58 PM
can you still get ACL race series stuff i thought shut shop ??
Posted 19 October 2019 - 03:05 PM
Posted 20 October 2019 - 10:40 PM
should be getting the bottom end back this week from the machine shop just have to wait to see what size bearings i nned to get also waiting to get balanced also.what is a good assembly lube to use on the bearings,i brought a tube of penrite assembly lube hope it will be ok.
Posted 25 October 2019 - 06:25 PM
I really dislike the penrite stuff. It's really stringy and almost slimish. I much prefer the CRC brand, has a consistency closer to a grease.
I recently made a pneumatic oil primer. Screws into the oil pressure sender hole. Fill it with 3-4L of oil, connect air to the regulator and pump away.
