engine bearings
11 replies to this topic
#1 lawn bowls
lawn bowls
  • 262 posts
  • Car:72 lj 4 door
Posted 03 October 2019 - 03:03 AM
ill be buying engine bearings very soon i can only find acl and king bearings.is there any difference between the race series and the normal bearings.it needs to suit boost for a 186
#2 Rockoz
Rockoz
  • 3,967 posts
  • Name:Rob
Posted 03 October 2019 - 10:32 AM
I can remember a time a while back when a good engine builder i was talking to said he recommended ACL race series to everyone he did machining work for.
I didnt get into the ifs and buts and whatnots with him at the time, but everything else he talked about was spot on information.
Not sure if this helps you exactly though.
But I guess a lot of it will come down to the boost pressure you will be dialling in, especially with head gaskets.
Sounds like you have your mind set on a decent combo.
Rob
#3 hanra
  • 10,832 posts
Posted 03 October 2019 - 11:26 AM
Is Myers doing all your machine work?
#4 Redslur
Redslur
    Has been Torana owner
  • 3,532 posts
  • Name:Gerry
  • Car:HQ GTS Replica 350.
Posted 03 October 2019 - 12:07 PM
Interesting as my engine machinist said something similar. I normally use KING bearings but on the current 355 I am building for a V3 supercharger I have gone with his recommendations and am fitting ACL.
Rob
#5 lawn bowls
lawn bowls
  • 262 posts
  • Car:72 lj 4 door
Posted 03 October 2019 - 02:32 PM
either myers or hm gem
#6 RedTaxi
RedTaxi
  • 61 posts
  • Name:Glen
  • Car:LX hatch
Posted 06 October 2019 - 11:34 AM
For my Hi-po (aspirated) 355 i asked my machinist who has some big runs on the board the same question. He said "race series, the std ones wont last."
#7 yel327
  • 13,085 posts
Posted 07 October 2019 - 07:44 PM
I’m using ACL race series too in my 377 SBC at the suggestion of my engine machinist.
#8 Big_Red
Big_Red
  • 79 posts
  • Name:Aaron
  • Car:LH Torana
Posted 19 October 2019 - 08:32 AM
ACL race series is for heavy duty, high stress applications. They are not as pliable as the standard range. Meaning they will take a pounding but will hurt the crank with and debris in the oil or loss of pressure etc. The standard bearings are much more sacrificial and protect the crank during a failure but will get hammered in high hp motors.
#9 Ice
  • 15,123 posts
Posted 19 October 2019 - 01:58 PM
Kings seem to be fine in a couple if engine I've had built
can you still get ACL race series stuff i thought shut shop ??
#10 I'm a Red Motor fiend
  • 758 posts
  • Name:Adam
  • Car:LJ 4 door, LC GTR
Posted 19 October 2019 - 03:05 PM
Yeah Gene, heaps of bearings available. I think they still produce them but only bearings. Shame they dont still do all their other stuff. Especially head gaskets for the mighty 6.
#11 lawn bowls
lawn bowls
  • 262 posts
  • Car:72 lj 4 door
Posted 20 October 2019 - 10:40 PM
should be getting the bottom end back this week from the machine shop just have to wait to see what size bearings i nned to get also waiting to get balanced also.what is a good assembly lube to use on the bearings,i brought a tube of penrite assembly lube hope it will be ok.
#12 Big_Red
Big_Red
  • 79 posts
  • Name:Aaron
  • Car:LH Torana
Posted 25 October 2019 - 06:25 PM
I really dislike the penrite stuff. It's really stringy and almost slimish. I much prefer the CRC brand, has a consistency closer to a grease.
I recently made a pneumatic oil primer. Screws into the oil pressure sender hole. Fill it with 3-4L of oil, connect air to the regulator and pump away.
