Dated GTR steel rim question
18 replies to this topic
#1 sibhs
sibhs
  • 2,699 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 12 October 2019 - 10:52 PM
G'day guys,
just wanted to get your thoughts on this date code on a 13inch 5.5 nibbed rim.
Firstly I bought 6 Nibbed 5.5 inch rims and am working my way through them by sand blasting and prepping.  The first one has GM logo and 73 stamped in it.  This makes sense.
The second has GM logo and 68 or 89 which none of these dates make sense. Surely in 1968 there were no 5.5 wide rimes in Torana offset then in 89 which I think this is due to more modern GM logo they wouldn't still be making Torana Rims?
Any thought or theories welcome.
Marty
Attached File  IMG_9105.jpg   257.9K   6 downloads
Attached File  IMG_9107.jpg   236.71K   9 downloads
#2 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,289 posts
  • Car:ɐuɐɹoʇ
Posted 13 October 2019 - 08:23 AM
Hi
This may be the answer:  Part Number 2813815 was still being used on the LX Torana.
Bazza
Edited by Bazza, 13 October 2019 - 08:24 AM.
#3 _LC870_
_LC870_
Posted 13 October 2019 - 08:47 AM
I  believe  that  the  second  rim  has  had  an  replacement  outer  put  back  on  the  original  wheel  center .
I  have  seen  quite  a  few  like  this .
Regards  LC870
#4 meanmachine72
meanmachine72
  • 2,004 posts
  • Name:Jono
Posted 13 October 2019 - 09:34 AM
i got a nibless centre put into another rim with date code i wanted, was charged 110 bucks to do so
#5 sibhs
sibhs
  • 2,699 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 13 October 2019 - 01:37 PM
Hi
Bazza
Thanks Baz,
So is it feasible that GMH still made rims ten years after that model finished?  I would of thought there would have been little demand for steel rims at this stage with Mags being the popular choice.
Marty
Regards  LC870
These rims had been sitting around for many years by the looks(10-15). I can't imagine the centre being changed all those year ago especially seeing the date is not special.
Marty
#6 dattoman
  • 16,461 posts
Posted 13 October 2019 - 04:17 PM
28P seems offset for a torana...sure they arent 4cyl commodore ?
#7 71xu1
71xu1
    Dave
  • 1,262 posts
  • Car:LC GTR XU1
Posted 13 October 2019 - 05:34 PM
Forgot about the Commodore wheels, but you jogged my memory i think you are right.
#8 _LONA-CK_
_LONA-CK_
Posted 14 October 2019 - 08:16 AM
Hi marty the date code is not on the outside of the rim, its on the rolled were the tube would be, I hope this helps cheers gong
#9 sibhs
sibhs
  • 2,699 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 14 October 2019 - 11:28 PM
Thanks for the replies.
If 4cyl Commodores came out with 13 inch rims that might be the answer. But if Gong says the date isn't on the outside?????
I'll check the inside tomorrow.
Marty
#10 UCgazman
UCgazman
    UC's FTW!
  • 1,342 posts
  • Name:Garth
  • Car:UC S̶u̶n̶b̶i̶r̶d̶ 5000!
Posted 15 October 2019 - 11:57 AM
They did, early Holden pattern too...
#11 yel327
  • 13,008 posts
Posted 15 October 2019 - 12:45 PM
I thought the 4cyl Commodore wheels had no caps or plastic caps thus no hubcap retainer bumps?
#12 claysummers
claysummers
  • 3,273 posts
  • Name:Clay
Posted 15 October 2019 - 03:59 PM
So you’re alluding to a cheap source for nibbless rim centres. I wonder how common they are. The 4 cylinder discs are touted as an alternative brake upgrade for early Holden running HR drum stubs, with adapter plates, the disc brake stubs and bolt ons being relatively dear to get hold of now, and the Torrie hubs having a lot more offset than HR. The studs are metric of course. Sorry, bit off topic.
#13 yel327
  • 13,008 posts
Posted 15 October 2019 - 04:47 PM
They were all thrown away just like the 4cyl Commodores themselves. I remember seeing them off to the scrappers minus headlights and tail-lights and possibly a few other bits and pieces that were saleable like combination switches. No-one even bothered pulling the engines apart for rods either like they did from UC Starfires prior to the XT5 engine release with WB and VC, as all those blue 6cyl had them.
The rotors are just LH-UC ones with metric studs I believe as you say. But I reckon you'll have more luck finding Torana stuff. Diffs were useless too as they were 3.9:1.
#14 claysummers
claysummers
  • 3,273 posts
  • Name:Clay
Posted 15 October 2019 - 06:27 PM
#15 UCgazman
UCgazman
    UC's FTW!
  • 1,342 posts
  • Name:Garth
Posted 15 October 2019 - 06:51 PM
I've converted a few from 4cyl to 6 or 8, never took much notice of the rims though - just chucked em out in favour of 15'' mags or pursuit rims...
#16 MFM
MFM
  • 687 posts
  • Name:Mark
  • Car:xu1
Posted 15 October 2019 - 06:56 PM
As Lona CK has said. This is my spare of my 5/72 XU1 nib less. Its in the middle where the tube sits.
Sorry didn't work. try this
#17 claysummers
claysummers
  • 3,273 posts
  • Name:Clay
Posted 15 October 2019 - 09:13 PM
So you changed to 120mm PCD gazman?
#18 UCgazman
UCgazman
    UC's FTW!
  • 1,342 posts
  • Name:Garth
Posted 16 October 2019 - 01:08 AM
Changed discs and calipers and the whole diff (4cyl diff housing has no sway bar mounts)...
#19 claysummers
claysummers
  • 3,273 posts
  • Name:Clay
Posted 16 October 2019 - 06:38 AM
