UC Alloy Brake Caliper Nipples
5 replies to this topic
#1 mugginz
mugginz
  • 313 posts
  • Name:Greg
  • Car:LH Torana
Posted 19 October 2019 - 11:08 PM
Does anyone know what type of bleeding nipples I need for a set of UC Torana (Commodore style) calipers and where to buy them by chance?
Thanks,
Greg
#2 claysummers
claysummers
  • 745 posts
  • Name:Clay
Posted 20 October 2019 - 06:32 AM
Just call Power Brakes at Gillies Plains SA. If they can’t help you no one can.
#3 Dr Terry
Dr Terry
  • 2,897 posts
Posted 21 October 2019 - 05:59 AM
The late UC with Commodore style calipers should be metric with 10 x 1 threaded bleeder nipples.
Dr Terry
#4 claysummers
claysummers
  • 745 posts
  • Name:Clay
Posted 21 October 2019 - 07:11 AM
Pretty well any bleed nipples you buy now will be 10mm hex head regardless of thread being metric or bsp etc. Excludes nos of course. Trying to bleed clutch slave on FB crash box recently I couldn’t get brake spanner to fit till I worked out it was 10mm. Got new nipples for old style wheel cylinders and they were 10mm as well.
#5 Dr Terry
Dr Terry
  • 2,897 posts
Posted 23 October 2019 - 07:14 AM
You're talking about the A/F size of the hex that the spanner fits over. You are correct these have been 10mm for years now.
However the thread is a different matter. Late UC will be metric, earlier cars will be UNF (in same cases UNC) but never BSP, that is a tapered plumbing fitting.
Dr Terry
#6 claysummers
claysummers
  • 745 posts
  • Name:Clay
Posted 23 October 2019 - 11:26 AM
Yes that's all I was trying to say dr t. Took me by surprise being on an old slave cylinder I had lying around.
Sent from my SM-A705YN using Tapatalk
