308 Intake filters
4 replies to this topic
#1 Swarbs
Swarbs
  • 1,662 posts
  • Car:LX 5000
Posted 22 October 2019 - 05:55 PM
Instead of reinventing the wheel i'm just wondering what others are / have used on there set ups
I'm running a 355 with VN heads
Torque power dual plane hi rise (air gap) manifold
Quickfuel carb
Rectangular hole in bonnet cut to A9X specs with std scoop
Wondering what fits and what others have found to be the best set up
#2 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 22 October 2019 - 06:42 PM
I presume that you mean an "air cleaner assembly" ? If so, we also assume that you would be going chrome ect, why not use a K&n extreme top style, you should be able to run, say a 9" × 4" under the scoop, if memory serves me correctly. Gary.
#3 76lxhatch
  • 7,156 posts
Posted 22 October 2019 - 07:23 PM
I have a round hole that fits the filter, but I made some mounts that double as the carb(/throttle body) nuts and provide a more secure surface for custom made air cleaner base/surround:
So it screws to these solid mounts rather than relying on the air filter stud:
Which only has to hold the filter:
The seal is just a length of old Commodore boot seal.
#4 Shiney005
  • 9,058 posts
  • Car:Toyota Mirai
Posted 23 October 2019 - 09:33 AM
X 3 on the K&N top.
#5 claysummers
claysummers
  • 3,343 posts
  • Name:Clay
Posted 23 October 2019 - 11:16 AM
Like your setup 76lxhatch
Sent from my SM-A705YN using Tapatalk
