steering column paint
4 replies to this topic
#1 tuxedoss
tuxedoss
  • 1,024 posts
  • Car:ss
Posted 22 October 2019 - 08:50 PM
Wondering what gloss level was used on black steering columns and also the pedals . I've got some satin black which looks good on top of dash but the original paint on steering column looks a bit glossy but doesn't look as glossy as 2 pack black would be . So what sort of black do I need for the column and pedals , is it normal 2K black gloss?
#2 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 23 October 2019 - 06:32 PM
Semi gloss, what you have is low gloss, gmh only ever called them semi or low gloss, once flattening base was added. Yes, the top of your dash & pillars should be your low gloss.
#3 tuxedoss
tuxedoss
  • 1,024 posts
  • Car:ss
Posted 23 October 2019 - 06:58 PM
Thanks that's what I expected, I'll go see the paint guy but can you normally get semi gloss off the shelf in 2K or do they just add flattener to a 2K gloss?
#4 yel327
  • 13,075 posts
Posted 23 October 2019 - 07:09 PM
Originally it would have been an acrylic medium gloss black air dry, same paint as used for lower body blackouts on GTS, Sandman etc. From memory 578-4149 is the Dulon code.
#5 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 24 October 2019 - 06:52 PM
Yes mate, they add flattening base correct. What Byron said on the shade code too.
