Cam journal Vs. bearing
15 replies to this topic
#1 RallyRed
  • 7,841 posts
Posted 29 October 2019 - 04:31 PM
Hi,
Pulled this engine to play with sump baffling/ gating.
Runs perfectly on the track, no dramas.
Just noticed the way the cam seems to sit about 2mm rearward compared to bearing location.?
Timing gears mesh well and dont foul on cover.
Is this at all normal.
COMP. cam, solid lifters, roller rockers.
Edited by RallyRed, 29 October 2019 - 04:33 PM.
#2 Lima31
Lima31
  • 874 posts
  • Name:Lee
Posted 31 October 2019 - 09:00 AM
Looks like it is still covering the oil feeds. I would be more concerned with looseness or excess play.
#3 warrenm
warrenm
  • 2,107 posts
  • Car:1972 LJ Torana
Posted 31 October 2019 - 10:26 PM
I'd pull the timing cover off & check the end float on the cam, I've seen them push the welch plug out the back.
#4 RallyRed
  • 7,841 posts
Posted 01 November 2019 - 05:56 AM
OK, Thanks gents.
Looking at the oil pump drive and dizzy drive,they are only about 1/2 meshing with the cam gear. Looking at the wear pattern, looks like it's been that way for a while....
Edited by RallyRed, 01 November 2019 - 05:57 AM.
#5 warrenm
warrenm
  • 2,107 posts
Posted 01 November 2019 - 06:25 AM
I'll add to my comment, the cam gear can get pushed of the cam, I'd be checking it, it's only one gasket. When the welch plug gets dislodged, the oil pressure is gone. I haven't got a pic, but the fix is to drill the end of the cam, fit a bolt & retainer plate.
#6 RallyRed
  • 7,841 posts
Posted 01 November 2019 - 11:12 AM
Yes, I'll back off the roller rockers and see how much float/ slop there is in the cam. Appears to be nil atm, but assume that is because the lifters are forced onto it via valve springs.
May as well get it sorted while it is out.
Thanks for the advice.
#7 RallyRed
  • 7,841 posts
Posted 01 November 2019 - 02:57 PM
As above, valve spring pressure removed, end float appx 20thou. ( too much I think ?)
#8 RallyRed
  • 7,841 posts
Posted 01 November 2019 - 03:00 PM
#9 RallyRed
  • 7,841 posts
Posted 01 November 2019 - 04:39 PM
Actually, that number is wrong...more like 1.5mm....tooo much.
Book says 0.007" max.
Off comes the balancer and cover .
#10 warrenm
warrenm
  • 2,107 posts
Posted 01 November 2019 - 10:40 PM
I normally aim for .004"or.005". The timing cover will have witness marks if it's walked.
#11 RallyRed
  • 7,841 posts
Posted 02 November 2019 - 03:52 PM
Ta Warren,..
Yes the timing gear has moved on the cam. Not loose, pressed back on flush...felt like a nice snug fit, HV oil pump gear/ torque needed to turn it may have drawn the cam rearward?...is there room within the timing case to drill & tap a locking screw ?..would be pretty tight?
#12 I'm a Red Motor fiend
  • 758 posts
  • Name:Adam
  • Car:LJ 4 door, LC GTR
Posted 02 November 2019 - 04:07 PM
Col, this is what I did with my set up. Drilled, tapped and inserted a grub screw with loctite.
#13 RallyRed
  • 7,841 posts
Posted 02 November 2019 - 06:54 PM
Luv your work Fiend!...thats what I was thinking, unless C/sunk, a bolt/ screw in the middle would stick out too proud with respect to the cover.
Thanks for the pic...speaks a thousand.
Col
Edited by RallyRed, 02 November 2019 - 06:55 PM.
#14 warrenm
warrenm
  • 2,107 posts
Posted 02 November 2019 - 09:13 PM
Your on the money, I machine a bit off the cam & maybe the gear to fit a washer & countersink hex head bolt.
Check the welch plug at the end of the cam tunnel.
#15 RallyRed
  • 7,841 posts
Posted 03 November 2019 - 08:40 AM
Thanks again Warren,....the welsh plugs are all newish.  As far as the rear one being  "eased" out by the cam movement, I will certainly have a look.
This forum is the best and getting real answers to real questions.......thanks Gents!
#16 RallyRed
  • 7,841 posts
Posted 03 November 2019 - 01:59 PM
Just some feedback Warren...rear welsh plug = good.
Fly wheel still in, used trusty Aldi umbilical cam.
