rust repair welding
9 replies to this topic
#1 limo
limo
  • 2,671 posts
Posted 31 October 2019 - 05:15 PM
Just finished fitting and welding in both front footwells in a LC. Roughed back the welds. I'M not best welder but capable. I weld both sides. I use a rotisserie. Question. Do people grind back welding flush with metal or leave it slightly proud?
#2 sibhs
sibhs
  • 2,699 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 31 October 2019 - 06:42 PM
Hi limo,
I weld one side and grind back flush.  Not as strong as leaving it raised but looks factory.
Marty
#3 claysummers
claysummers
  • 3,273 posts
  • Name:Clay
Posted 31 October 2019 - 07:02 PM
I weld either and sometimes both sides, depending what’s accessible, as long as you can get the grinder on the outside weld. Grind underside flush where ever it can be seen. Not as critical on top where it is covered over.
#4 71xu1
71xu1
    Dave
  • 1,262 posts
  • Car:LC GTR XU1
Posted 31 October 2019 - 10:46 PM
I butt weld on one side, (outside) make sure I have good penetration, grind flat outside and either leave penetrating weld if not seen at all or dress up slightly if not seen just to smooth out, if seen grind flat. Be very careful if you have lap welded as you will leave the edge very thin and susceptible to rust and being very weak like thin foil if you try to grind the weld flush.
#5 limo
limo
  • 2,671 posts
Posted 01 November 2019 - 12:24 AM
I rarely lap weld but when I do I fill and grind flat on out side to be painted then weld and leave the inside. If I can get to it. When I did complete wheel arch I couldn't get inside fully so drilled holes from outside into over lap. Then welded through and filled holes. But floor pan I leave both sides slightly up then with stone guard under and spray sealer inside levels out. Probably do lot more work than needed but feel better about the finished job.
#6 limo
limo
  • 2,671 posts
Posted 01 November 2019 - 12:31 AM
This one I'm working on is real basket case. Had more hits than ABBA. Lots of damage and previous repairs. Without doing the rust. Been sitting 10 years as shell waiting for me to get interested.
#7 _LONA-CK_
_LONA-CK_
Posted 01 November 2019 - 07:56 AM
I'm with clay, all the way.
Cheers gong
#8 71xu1
71xu1
    Dave
  • 1,262 posts
  • Car:LC GTR XU1
Posted 02 November 2019 - 07:48 PM
A picture says a thousand words. FC Holden ute rear wheel arch.
#9 71xu1
71xu1
    Dave
  • 1,262 posts
  • Car:LC GTR XU1
Posted 02 November 2019 - 07:52 PM
Attached File  5B3E90C7-6441-481B-A018-CCAEDE79C613.jpeg   89.53K   3 downloadsAttached File  73B36E1C-806D-434D-8384-CECE4B7ED69F.jpeg   99.08K   6 downloads
Edited by 71xu1, 02 November 2019 - 08:02 PM.
#10 71xu1
71xu1
    Dave
  • 1,262 posts
  • Car:LC GTR XU1
Posted 02 November 2019 - 07:58 PM
Attached File  image.jpg   173.55K   5 downloads
