179 budget build
3 replies to this topic
#1 claysummers
claysummers
  • 3,326 posts
  • Name:Clay
Posted 05 November 2019 - 10:14 AM
Have a low mileage HP motor i picked up from a mate and I've been collecting a few bits off Gumtree to throw together a warm street combo for my FB ute. I am sticking with the three speed crash box as the floor is too good to cut and I want to have original floor covering. Currently has the 3.89:1 diff but will no doubt go taller depending what comes along. I do have a few 3.08:1 centres lying around in varying condition and will try and run as tall tyres as I can.
Parts I have accumulated are WW carb from a 253 HQ manual, on factory WW manifold, X2 headers, 186S headers, 6° Bosch electronic dizzy. Original head just needs a lap or I have a stage 1 YT spec 202 head I picked up. Non adjustable rockers, double (dampeners) springs, big inlet valves, port and post job.
Picked up an unused Dynotec CM205D cam for $100. I am thinking to use this cam with the worked head but concerned the lift may be a bit taxing. Advertised at 429. I really wanted something a bit milder like a torque economy grind just for a bit of a lopey idle. Something that would work with the stock head even.
Any advice gratefully accepted red six gurus.
Clay
Sent from my SM-A705YN using Tapatalk
#2 Rockoz
Rockoz
  • 3,964 posts
  • Name:Rob
Posted 05 November 2019 - 10:54 AM
Search google for old johnno.
You will quickly find his hot 6 bible.
Follow its instructions and you wont go wrong.
Rob
#3 claysummers
claysummers
  • 3,326 posts
  • Name:Clay
Posted 05 November 2019 - 11:13 AM
Thanks Rob. Yes I've read a bit of his stuff. Will revisit.
#4 claysummers
claysummers
  • 3,326 posts
  • Name:Clay
Posted 05 November 2019 - 09:18 PM
According to old Jonno’s specs my cam is right in between a mild street cam and slightly warmer with lumpy idle. My main concern is coil bind at 0.429” lift. I hope the modified head has had longer springs installed with seats lowered and/ or offset retainers. I suppose I should be able to compare to my standard head. Ultimately I will dummy assemble and turn by hand I suppose.
