Door Striker
8 replies to this topic
#1 _Rustynutz_
_Rustynutz_
Posted 08 November 2019 - 09:04 AM
Hi guys I was aligning my doors on my LH and the rear passengers striker retaining clip fell into the wheel well any ideas how to retrieve or how to fit a new one thanks.
#2 Statler
  • 6,282 posts
Posted 08 November 2019 - 03:32 PM
Huh?
rear passengers striker retaining clip ?
#3 _Rustynutz_
_Rustynutz_
Posted 08 November 2019 - 03:53 PM
Okay maybe not a clip but the striker threads into it .
#4 Cook
Cook
  • 1,505 posts
Posted 08 November 2019 - 04:43 PM
Sorry Peter I can't help you but am wondering, shouldn't that nut sit in some form of cradle to make it captive, but with some adjustability, otherwise how do you change strikers? Surely the gurus can advise. Cheers Ron
#5 muzzta
muzzta
  • 264 posts
Posted 08 November 2019 - 05:39 PM
Magnets? my go to on dropped/lost stuff
Muz
#6 _Rustynutz_
_Rustynutz_
Posted 08 November 2019 - 06:59 PM
Magnets will just stick to the inner body yep I need a guru on this one, not sure how people change over strikers 😩
#7 muzzta
muzzta
  • 264 posts
Posted 09 November 2019 - 12:03 AM
Fair enough , I used electric magnets at times. all good I know your pain on dropping shit.
Best of luck
Muz
Edited by muzzta, 09 November 2019 - 12:11 AM.
#8 76lxhatch
  • 7,153 posts
Posted 09 November 2019 - 05:10 AM
Yes it can move around a little but is (supposed to be) held by metal tabs inside the panel. It (should) sit there by itself, this also holds it rotationally so you can tighten the striker. So to fix it properly you might need to cut something open anyway :-(
edit: sorry bad advice removed, you can only get to the vent area via the boot
Edited by 76lxhatch, 09 November 2019 - 05:12 AM.
#9 _Rustynutz_
_Rustynutz_
Posted 09 November 2019 - 10:59 AM
I have to get the rear passenger floor pans replaced so The best way is to cut an access retrieve it and re attach 😀
