XU1 spare wheel fitment
13 replies to this topic
#1 MFM
MFM
  • 687 posts
  • Name:Mark
  • Car:xu1
Posted 14 November 2019 - 01:35 PM
This topic has been discussed before but I just received a repro spare wheel tie down rod and went to fit it and just want to make sure I've secured the spare correctly. I have a workshop diagram but just want to be certain because once its secured its very unlikely I will ever need it (famous last words). Spare is the original nibless that came with the car. Where exactly does the jack sit underneath the spare?
#2 MFM
MFM
  • 687 posts
  • Name:Mark
  • Car:xu1
Posted 14 November 2019 - 02:56 PM
Photo/s would be great if someone has any.
#3 Indy Orange
Indy Orange
  • 2,848 posts
  • Name:Paul
Posted 14 November 2019 - 04:16 PM
The lower diagram is for LCXU1 and GTR .LJXU1 and GTR may have been the same.
Edited by Indy Orange, 14 November 2019 - 04:17 PM.
#4 RallyRed
  • 7,841 posts
Posted 14 November 2019 - 04:34 PM
The GMH factory "shop manual - LJ  Supplement ", does not show a difference for LJ, so guessing the above is all good for both models
#5 MFM
MFM
  • 687 posts
  • Name:Mark
  • Car:xu1
Posted 14 November 2019 - 08:08 PM
Ok this makes sense. I assume the jack is wound up somehow underneath the rim until it connects the inside of the rim to keep it from moving around. Thanks for that!!
#6 73SUNBURSTEXYOUWON
73SUNBURSTEXYOUWON
  • 807 posts
  • Name:JASO
Posted 14 November 2019 - 08:54 PM
The Jack seems to be laid on its side somehow. Located above the wheelarch in boot, in the bracketry just below the boot hinge.
See Torana Tough book page 104.
#7 MFM
MFM
  • 687 posts
  • Name:Mark
  • Car:xu1
Posted 14 November 2019 - 09:07 PM
Thats weird? I guess as long as it doesn't move around or rattle. Might try what the diagram recommends and see if it works
#8 crabba67
crabba67
  • 903 posts
  • Name:anthony
Posted 14 November 2019 - 09:58 PM
The information on page 104 in the torana tough book about the bottle jacks is incorrect both blue and black were used at Adelaide and ONLY black in Brisbane for the LJ torana.
The picture on page 104 is NOT from me....Also the jack in the picture is the incorrect blue
#9 Indy Orange
Indy Orange
  • 2,848 posts
  • Name:Paul
Posted 14 November 2019 - 11:08 PM
Edited by Indy Orange, 14 November 2019 - 11:12 PM.
#10 Indy Orange
Indy Orange
  • 2,848 posts
  • Name:Paul
Posted 14 November 2019 - 11:11 PM
#11 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 15 November 2019 - 04:48 PM
Stick with this set up Mark, the bottom fitment is the correct 1 for you.
#12 MFM
MFM
  • 687 posts
  • Name:Mark
  • Car:xu1
Posted 15 November 2019 - 06:24 PM
Thanks Gary thats what I did, just wasn't sure of the jack placement so I placed it like the diagram then reached under the wheel with right arm and made a couple of hand turns of the jack so it pushes up on the rim effectively stopping the jack moving around. Not sure if this is what factory recommend.
#13 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 15 November 2019 - 08:29 PM
That will do it mate, can't remember if the top piece of the jack fits in the rim groove or a stud hole. But you're spot on now. Did you buy the Rares spares retainer ? Gary.
#14 sibhs
sibhs
  • 2,703 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 16 November 2019 - 03:15 PM
I've found the spare wheel retainer to be next to useless.  Always coming loose and hard to use.
Marty
