HI have a powerglide behind a 1Jz in a Lh torana, and i have a BTE single sealing ring input shaft and wonder if it is making my box get hotter quicker as its gos up about 20 degs after a pass down the 1/4, any one used one of these types of input shaft ?
powerglide getting hot
Posted 24 November 2019 - 07:06 PM
Posted 26 November 2019 - 03:08 PM
Posted 29 November 2019 - 05:58 PM
75'c drive down the road, around 85'c -90'c in bad traffic, sensor is in the back of a cast alloy pan. I have seen a video where a trans builder in America wont use single seal input shafts, as he reckons it make then run hotter, not sure if it just a story, as BTE and huges make the single seal shafts,
i just don't want to burn another box ,
it has 7 clutches in high, tci manual valve body with brake, roller bearing for thrust at back of pump, large cast pan,5k convertor
https://www.facebook...list_video_list
Posted 29 November 2019 - 06:12 PM
