LX steering arm bolts
3 replies to this topic
#1 tuxedoss
tuxedoss
  • 1,027 posts
  • Car:ss
Posted 02 December 2019 - 06:29 PM
I'm sure these are the original holden bolts and are correct as I labeled them when I took them out but the rear one that threads into the arm seems too short, with the spring washer and disc shield  the end of the bolt is about  4mm short of the end. Is this normal? Bolts are 30mm or 1 1/4" looks like it needs a 1 1/2"
#2 tuxedoss
tuxedoss
  • 1,027 posts
  • Car:ss
Posted 02 December 2019 - 06:58 PM
Just found this in the parts book which shows it as 1 1/4" so seems correct but would like it to go to at least the end of the threaded hole
#3 308 Sunbird
308 Sunbird
  • 975 posts
  • Name:Stuart
Posted 03 December 2019 - 10:39 AM
I thought the same thing when I did my front end up but l know mind is original.
#4 yel327
  • 13,720 posts
Posted 03 December 2019 - 11:51 AM
It is a long time since I played with Tirana’s, but when I did I don’t recall ever having the steering arm bolts that short. I’m certain I would have questioned it too. It had UC steering arms on HK-WB stubs but can’t recall if I used Holden/Statesman bolts or Torana/Sunbird ones
