Coolant Mix
4 replies to this topic
#1 _LH8VD69_
_LH8VD69_
Posted 10 January 2020 - 09:44 PM
Hi all,
This could be a straight stupid question but what do you guys recommend coolant wise for my engine bare in mind it’s alloy heads, alloy radiator and electric CVR?
I’m only asking as I’ve only ever had all iron 308’s and usual radiator and I’m not sure what would be best
#2 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 10 January 2020 - 10:10 PM
Pretty sure nulon do a coolant to suit all engine metals like yours, can't remember what it's called though. Jump on their coolant guide & have a look though mate.
#3 warrenm
warrenm
  • 2,106 posts
  • Car:1972 LJ Torana
Posted 10 January 2020 - 11:04 PM
It's not advisable to put coolant into a new engine until it's done a couple of heat cycle's, just to give the head gasket a better chance of sealing.
#4 _LH8VD69_
_LH8VD69_
Posted 11 January 2020 - 03:02 AM
So just run distilled water?
#5 warrenm
warrenm
  • 2,106 posts
Posted 11 January 2020 - 05:38 AM
You can use distilled water if you like, I personally just use tap water. Start the engine & let it get to operating temp. a couple of times, then let some enough water out to put the coolant in.
