Barra and ZF 6 speed
5 replies to this topic
#1 tonytorana
tonytorana
  • 29 posts
  • Name:Tony Parker
  • Car:lx sedan
Posted 11 January 2020 - 07:25 AM
Hello everyone I'm planning to put an XR6 Turbo motor and ZF 6 speed into my LX four door sedan. Ive searched though the forum and only found one thread that covered the topic however it seemed to have went nowhere.
Has anyone on here done the conversion? If so I would love to hear about it.
#2 yel327
  • 13,081 posts
Posted 11 January 2020 - 08:02 AM
I did look at a VH 265 R/T engine in my LX hatchback years ago. It looked like there was going to be firewall clearance issues and possible radiator move. I gave up due to sump and oil pump location. The Ford 6 is a similar size so you may have similar issues, but as you are going to have to destroy the tunnel to fit the 6spd you can probably modify the firewall at the same time.
I’d also consider an aftermarket front end with power steering rack too, will give you lots more clearance.
Sounds like fun. If it was me though I’d be doing it to a Cortina like attached, but leave it looking like a Vicar’s car
https://www.gumtree....-xle/1237727952
#3 tonytorana
tonytorana
  • 29 posts
  • Name:Tony Parker
  • Car:lx sedan
Posted 11 January 2020 - 11:08 AM
Im hoping to be able to hookup the transmission to the column shifter as well if possible. I imagine making engine mounts, modifying the sump and expanding the trans tunnel would be the main issues to work around
#4 yel327
  • 13,081 posts
Posted 11 January 2020 - 11:25 AM
I think you’ll struggle with a 6spd column. You may have to go to a push button controller.
https://www.marks4wd...ns/gsm5000.html
#5 tonytorana
tonytorana
  • 29 posts
  • Name:Tony Parker
  • Car:lx sedan
Posted 11 January 2020 - 06:32 PM
I should be Right to machine up a devise that uses the position of the shifter in the column to tell the transmission what to do electronicly. I have an electrical engineer mate to help with that as well
#6 Big_Red
Big_Red
  • 79 posts
  • Name:Aaron
  • Car:LH Torana
Posted 22 January 2020 - 07:19 AM
Zf 6speed still use a cable to the trans. The manual 'sports' shifting is done electronically.
