Street/Strip 202 Build
110 replies to this topic
#1 I'm a Red Motor fiend
  • 767 posts
  • Name:Adam
  • Car:LJ 4 door, LC GTR
Posted 13 January 2020 - 07:41 PM
Howdy all, there hasn't been anywhere near enough Holden 6 goodness on here lately for us tragics so thought I'd start a thread covering my latest build.
Kept munching bearings in the old block so I cracked the shits, binned it and am starting afresh.
Had a 40thou over QL prefix red laying around so had it sonic tested - going to 60thou will be a little thin in a couple of bores front side but is usable.
Went round and saw the master Tony Knight and the build begins.
Red cranked, 9 port, 2" SU fed.
Attached File  Resized_20200110_155341.jpg   179.44K   22 downloadsAttached File  Resized_20200110_155346.jpg   82.95K   18 downloadsAttached File  Resized_20200110_165118.jpg   106.95K   17 downloadsAttached File  Resized_20200110_165406.jpg   140.34K   16 downloads
The crank after TK finished with it. Snout drilled for balancer bolt (Romac) flange drilled for flywheel dowells (Yella Terra 8.6kg)
#2 I'm a Red Motor fiend
  • 767 posts
  • Name:Adam
Posted 13 January 2020 - 07:49 PM
Block was pretty rusty inside so it got a molasses bath.
Cleaned up nice, drilled for external oil feeds.Attached File  Resized_20200113_103448.jpg   144.55K   17 downloadsAttached File  Resized_20200113_103450.jpg   131.64K   13 downloadsAttached File  Resized_20200113_103459.jpeg   178.58K   17 downloadsAttached File  Resized_20200113_103506.jpg   181.89K   15 downloadsAttached File  Resized_20200113_103509.jpeg   131.78K   15 downloads
will be running ACL Race Series pistons, Blue Motor rods ARP bolts, main and headstuds. Race Series bearings all the usual stuff inside.
#3 I'm a Red Motor fiend
  • 767 posts
  • Name:Adam
Posted 13 January 2020 - 07:52 PM
TK gave it a taller grout fill today.Attached File  Resized_20200113_125725.jpg   111.61K   16 downloads
Tunnel will be line bored and honed shortly.
Stay tuned, plenty more Holden 6 goodness to come.....
#4 RallyRed
  • 8,213 posts
Posted 13 January 2020 - 08:07 PM
Good stuff!
#5 _Lazarus_
_Lazarus_
Posted 13 January 2020 - 09:39 PM
Does he prefer red cranks ?
#6 Ice
  • 15,221 posts
Posted 13 January 2020 - 10:32 PM
Love the red 6 looks good Adam
love seeing brand new engine builds keep the pics coming
cheers G.
#7 _lawn bowls_
_lawn bowls_
Posted 14 January 2020 - 12:24 AM
what else are you doing to the engine and car?what are your goals at the drags?
#8 I'm a Red Motor fiend
  • 767 posts
  • Name:Adam
Posted 14 January 2020 - 04:43 AM
Red crank was my choice.
#9 I'm a Red Motor fiend
  • 767 posts
  • Name:Adam
Posted 14 January 2020 - 04:45 AM
Driving it
Going fast
#10 TK383
TK383
  • 76 posts
  • Name:Tony
  • Car:Blue one
Posted 14 January 2020 - 08:06 AM
Red crank is much lighter, picks up rpm quicker. Plenty strong in an NA application like this.
Blue cranks are good for boosted engines.
#11 gad05
gad05
  • 421 posts
  • Name:Graham
  • Car:73 lj 2 door , 74 lj sedan.
Posted 14 January 2020 - 10:40 AM
Good to see Adam, looking forward to this build.
Building my own rocket later in the year.
Cheers Graham.
#12 claysummers
claysummers
  • 3,715 posts
  • Name:Clay
Posted 14 January 2020 - 11:58 AM
You’ll run a lightened flywheel, maybe blue one?
Looking forward to progress.
#13 I'm a Red Motor fiend
  • 767 posts
  • Name:Adam
Posted 14 January 2020 - 12:21 PM
Flywheel is Yella Terra billet 8.6kg.
#14 I'm a Red Motor fiend
  • 767 posts
  • Name:Adam
Posted 14 January 2020 - 12:25 PM
Cylinders have now been bored.
Grout ground for water pump impeller clearance.
Will be honed next once the grout had fully cured.Attached File  Resized_20200114_111226.jpg   91.82K   14 downloads
Attached File  Resized_20200114_111223.jpg   121.51K   17 downloads
#15 _digger_
_digger_
Posted 15 January 2020 - 07:51 AM
coming along nicely, i might need bite the bullet to get TK to do mine as he did the head
Edited by digger, 15 January 2020 - 07:53 AM.
#16 I'm a Red Motor fiend
  • 767 posts
  • Name:Adam
Posted 15 January 2020 - 09:01 AM
Yeah Tony reconditioned my head for this build a while back.
Got it flowing better. Flows enough to support 300hp which he seems to think we may crack on the dyno in the very near future.
Tis an open chamber but has had at least 100thou removed, static comp will be at 11:1Attached File  Resized_20200114_163646.jpg   152.68K   18 downloads
#17 _digger_
_digger_
Posted 15 January 2020 - 09:56 AM
what spec cam did he recommend for you?
#18 TK383
TK383
  • 76 posts
  • Name:Tony
  • Car:Blue one
Posted 15 January 2020 - 11:01 AM
264/262 on 106, 1.6/1.5 rocker combo, .596/.530 valve lift.
#19 I'm a Red Motor fiend
  • 767 posts
  • Name:Adam
Posted 15 January 2020 - 12:12 PM
^^^^ only mild, but should still be good fun 🤯
#20 _lawn bowls_
_lawn bowls_
Posted 15 January 2020 - 08:12 PM
that camshaft is a lot more than mild
#21 I'm a Red Motor fiend
  • 767 posts
  • Name:Adam
Posted 16 January 2020 - 03:12 AM
Yep
#22 Gatti
Gatti
  • 348 posts
  • Car:LJ 2 Door
Posted 16 January 2020 - 07:56 AM
Great work!
Can't wait to see the result
#23 I'm a Red Motor fiend
  • 767 posts
  • Name:Adam
Posted 17 January 2020 - 12:07 PM
BA Falcon windage tray trial fitment. TK was pleased at the ease and minimal modification required to make this fit.Attached File  Resized_20200117_110137.jpg   163.6K   24 downloads
#24 yel327
  • 13,788 posts
Posted 17 January 2020 - 02:01 PM
Geez, the crank would almost fit!
#25 Com_VC
Com_VC
  • 411 posts
Posted 17 January 2020 - 02:44 PM
That windage tray looks like a good fit.  Is there an easy way to get one without ending up with a whole motor though??
