Street/Strip 202 Build
110 replies to this topic
#26 TK383
TK383
  • 76 posts
  • Name:Tony
  • Car:Blue one
Posted 17 January 2020 - 02:48 PM
I just called a wrecker & asked for one, $90 delivered.
#27 I'm a Red Motor fiend
  • 767 posts
  • Name:Adam
  • Car:LJ 4 door, LC GTR
Posted 17 January 2020 - 06:28 PM
.035" being taken off to get em' up at the top
Attached File  Resized_20200117_151617.jpg   205.23K   10 downloads
Done
Attached File  Resized_20200117_165221.jpg   195.81K   11 downloads
#28 I'm a Red Motor fiend
  • 767 posts
  • Name:Adam
Posted 17 January 2020 - 06:32 PM
Oil pump mods completeAttached File  Resized_20200117_165311.jpeg   45.51K   17 downloads
Attached File  Resized_20200117_165304.jpeg   119.51K   14 downloads
Attached File  Resized_20200117_165249.jpg   124.28K   13 downloads
Attached File  Resized_20200117_165243.jpg   115.39K   14 downloads
#29 Com_VC
Com_VC
  • 411 posts
Posted 17 January 2020 - 08:29 PM
Any plans for the oil pickup?
#30 I'm a Red Motor fiend
  • 767 posts
  • Name:Adam
Posted 18 January 2020 - 04:02 AM
3/4 inch inside the sump, same size external line.
#31 jd lj
jd lj
  • 2,120 posts
  • Name:James D
  • Car:LJ
Posted 18 January 2020 - 06:44 AM
What sump are you planning on using?
#32 I'm a Red Motor fiend
  • 767 posts
  • Name:Adam
Posted 18 January 2020 - 09:59 AM
Attached File  Resized_20200117_151552.jpg   103.98K   14 downloads
Attached File  Resized_20200117_145012.jpg   121.57K   12 downloads
Pick up is 3/4" pipe as said, and I just welded a stock pickup head to it.
#33 Com_VC
Com_VC
  • 411 posts
Posted 18 January 2020 - 11:46 AM
Do you think the additional windage tray you added to the sump is required seeing you have the falcon one mounted to the engine?
#34 Stinga
Stinga
  • 2,114 posts
  • Name:Stinga
Posted 18 January 2020 - 03:26 PM
watching this one, love a good six build!
#35 I'm a Red Motor fiend
  • 767 posts
  • Name:Adam
Posted 20 January 2020 - 02:51 PM
Few more pics. Progressing nicely. Cam arrived today so is being dialled in.
Attached File  Resized_20200120_094533.jpg   156.14K   17 downloads
Attached File  Resized_20200120_094527.jpg   159.87K   12 downloads
Attached File  Resized_20200120_144010.jpg   134.87K   15 downloads
#36 I'm a Red Motor fiend
  • 767 posts
  • Name:Adam
Posted 20 January 2020 - 07:49 PM
Attached File  Resized_20200120_155929.jpg   175K   17 downloads
Bottom end basically now complete.
Attached File  Resized_20200120_161936.jpg   188.49K   28 downloads
Head on, pushrod length sorted.
#37 Ice
  • 15,221 posts
Posted 20 January 2020 - 07:59 PM
Gee that head aint going nowhere
#38 I'm a Red Motor fiend
  • 767 posts
  • Name:Adam
Posted 20 January 2020 - 08:04 PM
Oil drain backs on head drilled out larger and radiused.
Running guide plates as the square shouldered push rod holes were drilled out larger to aid drain back.
Using an MLS head gasket.
Edited by I'm a Red Motor fiend, 20 January 2020 - 08:07 PM.
#39 I'm a Red Motor fiend
  • 767 posts
  • Name:Adam
Posted 21 January 2020 - 03:57 PM
Attached File  Resized_20200121_093628.jpg   79.32K   13 downloads
Cam drilled and tapped for bolt to stop the gear going walkies.
Attached File  Resized_20200121_125450.jpg   145.22K   15 downloads
External lines sorted.
Rockers on and lashed
Attached File  Resized_20200121_141706(1).jpg   190.23K   15 downloads
#40 FNQ
FNQ
  • 118 posts
  • Name:Darryl
  • Car:lc
Posted 21 January 2020 - 05:14 PM
very neat
#41 _lawn bowls_
_lawn bowls_
Posted 21 January 2020 - 06:10 PM
what roller rockers are you using and ratio
#42 I'm a Red Motor fiend
  • 767 posts
  • Name:Adam
Posted 21 January 2020 - 07:00 PM
Erson 1.6 inlet, Yella Terra 1.5 exhaust.
#43 I'm a Red Motor fiend
  • 767 posts
  • Name:Adam
Posted 22 January 2020 - 12:13 PM
Finished.
Attached File  Resized_20200121_150642.jpeg   32.52K   38 downloads
Attached File  Resized_20200121_150648(1).jpg   167.61K   20 downloads
Attached File  Resized_20200121_150653.jpg   103.41K   20 downloads
Engine will be dynoed on Friday.
Will post the results.....
#44 koalasprint
koalasprint
  • 297 posts
  • Name:Steve
  • Car:LX SS Hatch
Posted 22 January 2020 - 01:28 PM
I have to make mention of the paint job. I wouldn't say it is a pet hate of mine if not done, but I do appreciate the extra effort done to paint a motor prior to final assembly so that mating surfaces and gaskets, etc don't get coated in paint. A shout out to your engine painter!
Cheers, Steve.
#45 gtrboyy
gtrboyy
  • 3,241 posts
Posted 23 January 2020 - 09:50 PM
Nice work.
#46 _lawn bowls_
_lawn bowls_
Posted 24 January 2020 - 01:42 AM
what is your drive line combonation and type of fuel and your goals at the drags.
#47 I'm a Red Motor fiend
  • 767 posts
  • Name:Adam
Posted 24 January 2020 - 04:47 AM
Will eventually have a muncie and borg warner with 4.11's behind it.
To be honest I haven't put that much thought into goals at the strip. It will see more street use and just occasional strip use for the fun of it.
#48 yel327
  • 13,786 posts
Posted 24 January 2020 - 07:24 AM
Cheers, Steve.
It does look nicer that way. You’d lose Concours points though if it was painted that way though!
#49 _LXT333_
_LXT333_
Posted 24 January 2020 - 06:48 PM
Finished.
Keen to hear how it went on the Dyno.
#50 LC-GTR-1969
LC-GTR-1969
    Shed tinkerer
  • 1,162 posts
  • Car:Which one?
Posted 25 January 2020 - 07:09 AM
Looking great mate. Keen to hear how it goes on the dyno. Please post the results. You will love the 2 inch SUs by the way, they're outstanding on a 9 port.
