So failed a rego inspection today because the ball joint was loose in the wishbone.
Pulled it out and the hole in the wishbone appears to be ok (measures at about 51.5 mm and seems to be still round, although you can see the spline marks on only about 1/2 of the diameter).
I was wondering if anyone knew what size that hole should be and what size oversize ball joints are?
