Barbados lx 4door build
33 replies to this topic
#1 Birch
Birch
  • 28 posts
  • Name:Birch barbados
  • Car:Lx 4 door
Posted 24 January 2020 - 05:19 PM
Just about to start my lx build this is my 1st full car build planning to make it look like a9x but with a few different mods
Car is 4 door rolling shell
For anyone that has done this build i would like to know in what order did they complete the project, just the main steps not expecting step by step just thought it would be good to find out from people that have learnt from there mistakes
#2 neglectedtorana
neglectedtorana
  • 965 posts
  • Name:Tom
  • Car:LX Torana Sunbird
Posted 25 January 2020 - 04:49 PM
I haven't done an A9X build but have done a 4 door build and lots of times I regretted getting the paint done too early
It is difficult to cut, drill or bend painted panels for me. Wish I had built the car in primer, stripped out the mechanicals and electrics then sent it to the panel shop for paint
#3 Statler
  • 6,282 posts
Posted 25 January 2020 - 05:02 PM
Make a plan & stick to it.
Get a whiteboard for the shed.
There's always down time waiting for parts etc. Use this time to clean / detail all of the parts , then wrap them up in plastic .
#4 Birch
Birch
  • 28 posts
  • Car:Lx 4 door
Posted 25 January 2020 - 08:59 PM
Thanks for the replies all help is much appreciated
#5 hanra
  • 10,831 posts
Posted 25 January 2020 - 10:40 PM
Do all the shitty jobs first.
Edited by hanra, 25 January 2020 - 10:40 PM.
#6 _Carcrazy_
_Carcrazy_
Posted 27 January 2020 - 10:18 AM
Paint last, before final assembly. Make sure all fits properly, gaps all good ect before paint
#7 Birch
Birch
  • 28 posts
  • Car:Lx 4 door
Posted 27 January 2020 - 02:13 PM
That's what I was thinking also
What's people's thoughts on getting car sandblasted pros and cons?
#8 snuff1966
snuff1966
  • 182 posts
  • Car:LH G pack
Posted 27 January 2020 - 05:42 PM
Sandblastings OK if they know what they're doing, but don't do the boot bonnet or roof.
#9 claysummers
claysummers
  • 3,308 posts
  • Name:Clay
Posted 27 January 2020 - 06:52 PM
Don’t use anyone unless recommended by someone you trust and you will be ok. Be sure your body and panels will be usable as it is a fair investment. Get everything two pack etch primed immediately.
The rest of the story is all good. You will have all the faults revealed and can work on them at your own pace.
#10 bags
bags
  • 78 posts
Posted 27 January 2020 - 07:58 PM
Going to be a nice project. Have fun with it and keep the updates coming
Sent from my SM-G970F using Tapatalk
#11 Birch
Birch
  • 28 posts
  • Car:Lx 4 door
Posted 29 January 2020 - 06:29 AM
Can anyone recommend a good sandblaster in Brisbane that has done some good work
Also what's the biggest legal wheel and tyre size for qld
#12 Mitchyboy
Mitchyboy
  • 390 posts
  • Name:Mitch
  • Car:Lh torana
Posted 29 January 2020 - 07:25 PM
Hey Birch
Is there much rust repairs to do on the car?
The way i am attacking mine is to leave the paint that's already on there and just reveal the parts that I am fixing 1 at a time.
The parts that i have stripped back fully and repairs I have completed I have coated in fish oil until I am completely ready for the epoxy primer.
My uncle's mate recommended this way to me and he is a panel beater/spray painter.
If you get it fully sand blasted then primed you will need to be removing the primer anyways in order to make all of your repairs.
Seems silly and will cost more money I believe.
Fish oil is cheap and works well and just wax remover will get it off.
Try and finish each job too, other wise you end up with alot of half done jobs.
Hope that helps bud
Enjoy
Sent from my SM-G965F using Tapatalk
#13 Birch
Birch
  • 28 posts
  • Car:Lx 4 door
Posted 17 February 2020 - 07:30 PM
Thanks for the tips Mitch and I've been looking at your build which will be very similar to mine keep up the good work mate
#14 Birch
Birch
  • 28 posts
  • Car:Lx 4 door
Posted 06 September 2020 - 11:01 AM
Have built rotisserie for car removed diff and front end previous owner has cut of engine mounts so im chasing a good detailed drawing to fabricate a new set if anyone could help or if any one has a kframe in bris area for sale
Any help would be much appreciated car will be running 304 or 308
#15 Shiney005
  • 9,029 posts
  • Car:Toyota Mirai
Posted 06 September 2020 - 12:52 PM
Probably best to source another K frame. If you get the engine mounts wrong, nothing else will go right. If you know a young bloke who is good on facebook, they should be able to find you one pretty quick.
#16 Rainman
Rainman
    Pain in the ar$e
  • 799 posts
  • Name:Ray
  • Car:SS Hatch
Posted 11 September 2020 - 06:18 PM
I thought removing the paint would show all the areas that require repair, then start the plan.
#17 Birch
Birch
  • 28 posts
  • Car:Lx 4 door
Posted 13 September 2020 - 11:53 AM
Thats the plan
#18 Birch
Birch
  • 28 posts
  • Car:Lx 4 door
Posted 12 January 2021 - 01:46 PM
Bit of an update on car
removed all drive train and suspension , i built a rotisserie then cleaned under side , pulled everything apart from panels off . Next step is to start some body work including modify tunnel to fit muncie
Trying to upload  some pics not real good on the ole computer
#19 Birch
Birch
  • 28 posts
  • Car:Lx 4 door
Posted 12 January 2021 - 02:01 PM
few pics
#20 Birch
Birch
  • 28 posts
  • Car:Lx 4 door
Posted 12 January 2021 - 02:06 PM
not to bad so far no big surprises
#21 Ricky Bobby
Ricky Bobby
  • 194 posts
  • Name:Harvey
  • Car:LJ 2 door, UC hatch
Posted 31 January 2021 - 02:53 PM
I would set a budget for the project and then double it !!!  Build the car so it starts,drives and stops then strip it for paint. You will learn all the skills you need as you go. Good luck and just persevere
#22 Shiney005
  • 9,029 posts
  • Car:Toyota Mirai
Posted 01 February 2021 - 09:45 AM
The body looks like LX, but that crossmember is pre RTS I think.
#23 Birch
Birch
  • 28 posts
  • Car:Lx 4 door
Posted 01 February 2021 - 03:20 PM
I measured the uca mount bolts to be 65mm which I understand it makes it rts but im chasing a another due to previous owner removing engine mounts if anyone has one in brissy area
#24 Birch
Birch
  • 28 posts
  • Car:Lx 4 door
Posted 01 February 2021 - 03:26 PM
cheers Ricky bobby for the advice mate waiting to find a kframe so I can bolt up engine and box to do the mods for the muncie
then paint underside is my plan
#25 Shiney005
  • 9,029 posts
  • Car:Toyota Mirai
Posted 02 February 2021 - 05:23 PM
Yep. 65mm is RTS. He may have removed the rag coupling cover as well? Maybe that was later on, but I'm sure at least some LX's had them.
