This is probably common knowledge so excuse my ignorance as a relative newby to this game, but I have just discovered that my May 72 LJ has all parts with manufacturing date codes of April 72 (D2) My Radiator (D2) brake booster, wiper motor, engine block, diff housing, heads and probably gearbox, but I can't find the date casting on it. Guessing all of you already knew this?
Torana LJ date coding of parts
Posted 09 February 2020 - 03:31 PM
Posted 09 February 2020 - 03:43 PM
I’d love to have an original date coded radiator for my green car...a cylinder head would be nice too, oh well
Cheers,
Liz
Posted 09 February 2020 - 05:30 PM
Liz its not luck its just money I knew the provenance of my car and payed accordingly for it 2 years ago in a private sale off a mate. You generally get what you pay for if you pay a lot. I think this theory applies to everything in life.
Posted 09 February 2020 - 05:48 PM
Is your booster 21.d.2 ? They are very hard to find
Posted 09 February 2020 - 05:54 PM
The gearbox date code is on the passenger side towards the front but can be difficult to read.
Almost everything is date coded.
Posted 09 February 2020 - 06:02 PM
Why would they be rare I wonder.?
Is the Distributor date coded?
Posted 09 February 2020 - 06:12 PM
See JP block/Diff housing/Radiator even spare steel rim. Funny how they all (except nibless spare) at D2. Gearbox has the yellow 'XU' stensil but I can't make out the date code.
Posted 09 February 2020 - 06:32 PM
Yes, agreed on that one. I know I’d have to pay a lot for the correct cylinder head if there was one pop up. M21 date code.
Cheers,
Liz
Posted 09 February 2020 - 06:42 PM
Can anyone tell me where to find the date code on my distributor? or is it staring at me?
Posted 09 February 2020 - 06:51 PM
The three numbers on the side stamped vertical only the week and year.
Posted 09 February 2020 - 06:54 PM
Mark that's the diff centre you need which was out of a xu1 built on the same day at Adelaide.
Posted 09 February 2020 - 06:55 PM
Posted 09 February 2020 - 06:59 PM
Posted 09 February 2020 - 07:06 PM
Sell me that diff centre Anthony ha ha ha I've spend $1800 on 2 x LSD centres and they both still whine at 60MPH, not happy. Desperate to find a 3.36 crown wheen & pinion that is in good condition that I can fit to my LSD
Posted 09 February 2020 - 07:12 PM
Found a vertical number closest to the block. Bloody hard to get your head down there by has '223' so not sure what that means.
Posted 09 February 2020 - 07:18 PM
The cast date, would be close to that, but Anthony you would have to know that they didn't hand pick a date coded part to go in a whatever date car, it was picked from a parts bin remember.
You're incorrect the parts like xu1 gearboxes,diff housings,diff centres and distributors are all in batches xu1's are not standard cars on the production line eg; baffled diff housings for xu1's build on the 4/9/72 to 8/9/72 at Adelaide are all 21H2D.
Posted 09 February 2020 - 07:34 PM
All good Mark March 72 Distributor.cheers
Posted 09 February 2020 - 07:40 PM
Ok thats good thanks Anthony. thanks for that.
Posted 09 February 2020 - 10:08 PM
Not many boosters with that date made so if
You wanted to find one very hard.
#20 _Daniel_
Posted 29 November 2020 - 06:47 PM
Hi just checking numbers on my Oct 73 GTR;
Engine JL431133 has date code 15K3
Head 2811930 has date code 12K3
Gearbox 7433771 has date code 10K3
Diff has date code 4K3
Carby 23-3078 3-42
From what i know the K is Oct, hence all the above should be correct ? only one im not sure is the carby ? I think 3 =1973 and 42 is the week number ?
TIA
Dan
#21
Posted 30 November 2020 - 06:42 AM
Carby 23-3078 3-42
TIA
Dan
If 3-42 is the date code on the carby then the 42nd week of 1973 would be mid October. Your GTR must be a late October completion date.
#22
Posted 30 November 2020 - 07:11 AM
#23
Posted 02 December 2020 - 12:01 PM
Were the carbs assembled in Australia?
If we talking about XU1 Zenith-Stromberg carbies, I believe that they are made in the UK.
All the single & dual barrel Bendix-Stromberg carbies from July 1957 to March 1980 (end of Red motor) are made in Australia.
Dr Terry
#24
Posted 02 December 2020 - 12:40 PM
Edited by yel327, 02 December 2020 - 12:40 PM.
#25
Posted 02 December 2020 - 01:24 PM
Meaning they’d be like Quadrajets where assembly dates are many months prior to the compliance date of the GMH vehicle in question. For example most GTS327 assembled between June and December 1968 have early January 1968 dates on their carbs. And sure, most of them are the same date, but an outlier or two have turned up.
Yeah, as per my post, the Aussie carbies (AFAIK made in Rockdale, Sydney) would've been close in date, but you would expect the UK ones to be dated 2-3 months prior.
Dr Terry
