lh bonnet hinges replacement
8 replies to this topic
#1 jef
jef
  • 35 posts
  • Car:LH SL
Posted 15 February 2020 - 09:01 PM
my bonnet hinges are stuffed, are people buying new ones or getting the billet ones, i see proflow, areoflow and bilss make them or is there some who repins the original. Do the aftermarket ones clear the heater box.
#2 LJ RB30
LJ RB30
  • 974 posts
  • Name:Trevor
Posted 15 February 2020 - 09:39 PM
http://www.gmh-toran...s-where-to-buy/
Link at bottom of this thread.
Havent used them personally.
#3 rodomo
  • 17,997 posts
Posted 15 February 2020 - 09:50 PM
Is your bonnet too high at the back?
#4 neglectedtorana
neglectedtorana
  • 965 posts
  • Name:Tom
  • Car:LX Torana Sunbird
Posted 16 February 2020 - 08:19 PM
Mine is too high at the back, are these reconditioned hinges a solution Rob?
#5 rodomo
  • 17,997 posts
Posted 16 February 2020 - 09:15 PM
Loosen the bolts that hold the hinge to the skirt.
Get a mate to push the bonnet all the way up while you tighten the bolts.
See how it sits then.
Let me know what happens.
#6 mugginz
mugginz
  • 325 posts
  • Name:Greg
  • Car:LH Torana
Posted 16 February 2020 - 10:26 PM
My bonnet sat high at the back and the thing that fixed mine was to counter intuitively raise the front of the hinge and hey presto all better. One hinge at a time I undid both bolts leaving the rear one with some resistance to it and rotated the hinge up at the front. Might help.
#7 neglectedtorana
neglectedtorana
  • 965 posts
  • Name:Tom
Posted 20 April 2020 - 03:49 PM
Worked for me, thanks Rob.
It did take some fiddling to get it better and it's still not perfect but a lot better. The rivets in mine have a lot of play.
Woohoo
#8 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 20 April 2020 - 04:46 PM
I rebuilt a set of hinges years back using stainless pins. They felt great when i put them in and bonnet lined up well.
After not much use, the stainless pins are now looser than the originals before i repinned them and i was struggling to get the bonnet all correct.
The original pins must be quite hard i guess.
I now have billet hinges with bearings. Way nicer and bought the hinge adjustment nicely back to close on centre of adjustment range with bonnet all lined up.
M@
#9 dattoman
  • 16,470 posts
Posted 20 April 2020 - 09:22 PM
https://www.rarespar...j-hx-hz-wb-pair
