Black motor power steering bracket
11 replies to this topic
#1 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,891 posts
  • Name:Maz
  • Car:72 LJ SL SEDAN.
Posted 22 February 2020 - 01:05 PM
Hi guys does this bracket suit power steering setup
A guys having problems fitting fitting a blue 202
power steering setup onto his black motor.car is a vh..
#2 IMORAL
IMORAL
    Bored
  • 2,567 posts
  • Name:Paul
  • Car:LX SS HATCH - IMORAL
Posted 22 February 2020 - 01:13 PM
Tell your other head not to post the same thing please
#3 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,891 posts
  • Name:Maz
Posted 22 February 2020 - 01:34 PM
Attached File  20200222_125600.jpg   209.37K   3 downloads
#4 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,891 posts
  • Name:Maz
Posted 22 February 2020 - 01:36 PM
What!
#5 dattoman
  • 16,470 posts
Posted 22 February 2020 - 05:20 PM
Thats ugly
I thought the power steer ant aircon bracket were the same beast
At least my VB was
Yet this ones different to what I remember
https://www.gumtree....roud/1186464972
More like this
https://www.autoware...mpressor-mount/
#6 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,891 posts
  • Name:Maz
Posted 23 February 2020 - 01:59 AM
Here"s how it looks on side of block.couldnt be
buggered moving car out for better pics.
Looks just an alternater bracket.
Attached File  20200223_024625.jpg   158.82K   5 downloads
Attached File  20200223_024711.jpg   139.49K   5 downloads
Edited by madtoranajzedded, 23 February 2020 - 02:06 AM.
#7 yel327
  • 13,081 posts
Posted 23 February 2020 - 04:50 AM
I always remember looking like the attached. The arm goes from the back of the pump to an engine mount bracket bolt.
Note that there are a few longer bolts and spacers that are needed too as the bracket attaches with engine bolts.
https://www.ebay.com...ItemCondition=4
#8 76lxhatch
  • 7,152 posts
Posted 23 February 2020 - 06:05 AM
The black engine in VK used a remote reservoir and the pump mounted low on the passenger side. I can't seem to find a photo but if memory serves the original bracket is quite small as it bolts close to the block, along the lines of the alternator one datto linked.
The blue which was originally in the VH used the integrated reservoir style pump on the driver side with a larger bracket more like what yel linked.
I think your bracket looks custom made, possibly mounts the VK style pump on the lower rubber eyelets close to the block, and the alternator up on the top one in conjunction with another bracket? The rubber mounts won't be very helpful, looks like they might be ends cut off a panhard rod.
#9 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,891 posts
  • Name:Maz
Posted 23 February 2020 - 04:27 PM
Thanks for the help yel327,76lxhatch. Very helpful.
Your probably right .i never actually got to see it
with everything attached. youngest brother had the
motor and swapped set of rebels for it to my other
brother so i dunno.
It may have been on an blue motor as i found blue
Paint on other side where its bolted to alt bracket.
Been under house roughly since 95-98.they have done a
pretty good job if someone made it..
Cheers .
#10 S pack
  • 15,538 posts
Posted 23 February 2020 - 04:58 PM
Agree.
WB, VC & VH had the blue motors. I suspect the 6cyl all used the same power steering pump mounting bracket which is the one Yel327 posted a link to.
#11 Dr Terry
Dr Terry
  • 3,276 posts
Posted 24 February 2020 - 03:09 PM
Commodore p/st pump mounts around this time were very confusing. VB 6-cyl, VC 6-cyl, & VH (3300 only) used the same drivers side mount as HQ-WB & uses the pump with the integral reservoir. These cars also had the alternator & a/c compressor (if fitted) on the passengers side of the engine. The bracket posted by MAZ is a aftermarket version of that mount, which does NOT mount the p/st pump.
VH 2850 & VK (carb & EFI) had the p/st pump hung under the alternator on the passengers side of the motor with a remote reservoir & the a/c compressor (if fitted) was mounted on the drivers side of the engine near no.1 & 2 spark plugs.
Dr Terry
#12 dattoman
  • 16,470 posts
Posted 24 February 2020 - 10:26 PM
Sorry guys
Brain fart
The bracket I was thinking of must have been aircon and alt
Seems I haven't taken pics of the PS bracket on the car
