Column Ignition Switch
7 replies to this topic
#1 lx308
lx308
  • 2,838 posts
  • Name:Tony
  • Car:Nuffin. Goin touring.
Posted 27 February 2020 - 04:33 PM
Anyone tried these?
I had to clean mine out after sitting for a few years & it's starting to play up again. Hoping these might be the easy fix.
https://www.rarespar...umn-hq-wb-lj-uc
#2 Statler
  • 6,282 posts
Posted 28 February 2020 - 01:11 PM
While I haven't purchased a repo / aftermarket ignition switch , i have seen countless complaints from people who have .
My 2c : Take the original to a locksmith & have them recondition it.
#3 hanra
  • 10,832 posts
Posted 28 February 2020 - 02:05 PM
Id just crack it open again clean up the terminals and give it a hit with dielectric grease. Cant beat OEM.
#4 Dr Terry
Dr Terry
  • 3,276 posts
Posted 28 February 2020 - 03:23 PM
I think you are confusing the ignition switch with the ignition/steering lock barrel. We've had many posts regarding cheap Chinese lock barrels but I haven't seen any issues with the switches.
A locksmith is not going to have crack at repairing an ignition switch, but he would be more than capable of repairing or re-keying an old genuine lock barrel.
Dr Terry
#5 lx308
lx308
  • 2,838 posts
  • Name:Tony
Posted 28 February 2020 - 05:12 PM
Dr Terry
Yep, I was referring to the lower switch, as what's in the link.
#6 Statler
  • 6,282 posts
Posted 29 February 2020 - 08:48 AM
Dr Terry
My bad.
#7 holdentoranaman
holdentoranaman
  • 113 posts
Posted 21 March 2020 - 10:17 PM
originals are easy to rebuild if you have some skill and patience . i just did a spare for my car as it has started sticking.
#8 jpxu1
jpxu1
  • 549 posts
Posted 22 March 2020 - 08:52 PM
A lot of times the problem with an ignition switch is incorrect alignment, from general wear, on the steering column in relation to the positions of the ignition lock.
If the problem is the switch itself, they can usually be cleaned and greased to get them working again. but it can be a tedious job. The aftermarket ones work fine and can be an easier solution.
Original ignition locks can quite often be repaired/rebuilt/re-keyed by a competent locksmith. Again aftermarket ones are available but they have different sized tumblers etc to the originals, so they cannot be re-keyed to match other locks or your key, nor can they be repaired (a locksmith will not touch them, even though they probably sell them). If your original ignition lock cannot be repaired you are far better off finding another original and having it rebuilt.
Cheers,
JPXU1
