Cracked door frame at hinge, common ? how to fix?
4 replies to this topic
#1 fuzzypumper
fuzzypumper
  • 929 posts
  • Name:Archie
Posted 27 February 2020 - 09:45 PM
Hi All,
I was paint striping the passengers front door  of the LH torana and found the metal frame of the door at
the lower hinge has cracks radiating from one of the bolt holes.
Wondering how common this might be?
How should I go about fixing these cracks with a MIG?
Do I cut through cracks then MIG?
Thanks.
#2 claysummers
claysummers
  • 3,326 posts
  • Name:Clay
Posted 27 February 2020 - 10:56 PM
Drill holes in the ends of the cracks. This will stop them from advancing further. Then plenty juice mig up.
#3 adrianh08
adrianh08
  • 219 posts
  • Name:Adrian Haynes
  • Car:1974 LH
Posted 28 February 2020 - 11:19 AM
Super common problem, especially on hatchback doors that are heavier.
You can definitely mig them up.
But its a good idea to remove the backing plate from behind first, then weld up, then return the backing plate. (Just a matter or bending one of the tabs that hold them in place to remove)
Otherwise you can accidentally weld the backing plate to the door itself which will cause a number of problems.
#4 fuzzypumper
fuzzypumper
  • 929 posts
  • Name:Archie
Posted 05 March 2020 - 10:40 PM
Thanks all for the advice.
Repair done by drilling holes at the end of cracks and MIG'ed.  I found it better to also drill holes along
the cracks and plug weld as i got better penetration. Sanded flat with belt sanding file.
On closer inspection I found more fatigue cracks on the lower bolt hole as well.
#5 claysummers
claysummers
  • 3,326 posts
  • Name:Clay
Posted 06 March 2020 - 07:20 AM
