Starter stays locked in,
13 replies to this topic
#1 _Carcrazy_
_Carcrazy_
Posted 03 March 2020 - 09:16 AM
Wondering if anybody can help. I recently did a motor change from a 6 to 8 in a LH torana. For the first few weeks every thing was good. Now every time I try and start car the starter stays locked in, and when I turn the key off, it still keeps turning the motor over. The only way to stop it turning off is to disconnect the battery. I tried disconnecting when running to the move car but when I disconnected the battery the motor then stopped. But the car does not have issues charging the battery while running. Tapping start er or solonoid does not help.
Any ideas or suggestions please
#2 yel327
  • 13,009 posts
Posted 03 March 2020 - 09:41 AM
I had the same issue with a starter on a 351C in a ski boat. Needed a new starter. I suggest changing it out with another one if you can borrow one to try.
#3 claysummers
claysummers
  • 3,273 posts
  • Name:Clay
The solenoid is sticking. Could be weak or broken return spring. Remove starter and overhaul.
#4 S pack
  • 15,522 posts
The contacts in the solenoid have welded themselves together thus keeping the solenoid energised.
Edited by S pack, 03 March 2020 - 09:42 AM.
#5 claysummers
claysummers
  • 3,273 posts
  • Name:Clay
Posted 03 March 2020 - 10:29 AM
When you reconnect the battery does it start cranking, or do you have to turn the key again?
#6 _Carcrazy_
_Carcrazy_
Posted 03 March 2020 - 11:51 AM
When we reconect battery it does not crank. Need to hit the key again to crank.
#7 yel327
  • 13,009 posts
Posted 03 March 2020 - 01:51 PM
Same as my boat was. As others have said probably the solenoid, I just got an exchange starter and it fixed it.
#8 dron
dron
  • 126 posts
  • Name:Darren
  • Car:UC
Posted 03 March 2020 - 05:10 PM
What type of starter? Old or new.   I had an aftermarket starter that needed the mount shimmed to give it the needed clearance between the gear and ring gear. If you tried to start it before I shimmed it the starter jammed in.
#9 _Carcrazy_
_Carcrazy_
Posted 03 March 2020 - 06:16 PM
Dron, will try that, it is a genuine holden starter that has been rebuilt a few years ago. Try a 2mm shim and see how it goes. Pulled it out tonight
#10 claysummers
claysummers
  • 3,273 posts
  • Name:Clay
Posted 03 March 2020 - 08:56 PM
You could check at the solenoid terminal for open circuit when key is released. It is possible although unlikely that the circuit remains energised although the key is released.
Check for voltage at solenoid terminal when key is released. If you don’t have a volt meter take off the terminal, then get someone to turn the key. Put terminal on, engine starts. Take off terminal, see what happens. Don’t short terminal to earth though. If it stops cranking then the ignition switch is faulty. If it keeps cranking then the solenoid is sticking. May also be due to miss alignment of drive gear as suggested above. I had a clearance problem when I fitted an aftermarket gear reduction starter once. The drive gear was slightly fouling ring gear causing the ring gear teeth to grind against the end of the drive gear. Not a nice sound. 2mm ally spacer fixed it.
#11 _Carcrazy_
_Carcrazy_
Posted 05 March 2020 - 07:57 AM
Guys, got the problem sorted, my local electrician remembered a circular put out over ten years ago about this, apparently some origonal starters needed this. He pulled the solonoid of and put a second small return spring in along with the origonal and it is now working fine. We checked the clearances with teeth in mesh position and starter did not need shim on installation. All good now.
#12 claysummers
claysummers
  • 3,273 posts
  • Name:Clay
Posted 05 March 2020 - 10:04 AM
#13 Heath
  • 18,299 posts
Posted 05 March 2020 - 11:22 AM
So it has two return springs in the starter motor solenoid?
Is this a Holden V8?
#14 _Carcrazy_
_Carcrazy_
Posted 06 March 2020 - 08:08 AM
Yes holden hq hj v8 starter motor. The second spring is shorter and washer between them
