Confirmation LJ?
17 replies to this topic
#1 RallyRed
  • 8,213 posts
Posted 10 March 2020 - 09:09 PM
Hi all,
Hoping for help to understand if this is definately LJ.
i.e not HR-K-T-G or even Q.
Edited by RallyRed, 10 March 2020 - 09:13 PM.
#2 dattoman
Posted 10 March 2020 - 10:03 PM
If that rotor is 256mm its LC-J
If its 270mm its KTG
As for the arms... LC-J is my guess... def not KTG
#3 claysummers
claysummers
  • 3,716 posts
  • Name:Clay
Posted 10 March 2020 - 10:24 PM
HQ are vented discs for a start. I didn’t think the HKTG calipers have the girlock script casting. Control arm looks to be LC LJ. But I thought the Torana rotors have slot holes. Other than that the disc to hub offset looks Torana, but could be HR. I’d be having a go at checking the king pin inclination in case someone has swapped HR stubs and discs way back when.
#4 S pack
  • 15,764 posts
Posted 11 March 2020 - 06:17 AM
What master Yoda said^^^^^
LC - LJ
#5 RallyRed
  • 8,213 posts
Posted 11 March 2020 - 07:23 AM
Thanks gents.
Yes, dumb question, HQ are slotted....doh.
Just to close the loop ..the Torana discs don't have "slot holes" that I am aware of.  Their discs look like little saucers, almost look too small to be true.
Thanks again
#6 RallyRed
  • 8,213 posts
Posted 11 March 2020 - 07:26 AM
p.s. hey Neil...how come your posts doesn't have a "like" button?
#7 hanra
  • 11,033 posts
Posted 11 March 2020 - 10:38 AM
Thanks gents.
Thanks again
The Morris 997 and 998 Cooper's had 7in Disc Rotors. The 1275 Cooper S's had 7.5in Disc Rotors.
I did a Honda Civic conversion on mine and now have massive 9.1in Disc Rotors.
#8 RallyRed
  • 8,213 posts
Posted 11 March 2020 - 10:41 AM
ha ha Brad..yeah, I remeber when I purchased my LC GTR back in the 70's....big selling point was that they had TEN INCH rotors...oooh the stopping power was immense.
#9 RallyRed
  • 8,213 posts
Posted 11 March 2020 - 12:10 PM
Correct you are brakemeister Thanks.
#10 claysummers
claysummers
  • 3,716 posts
  • Name:Clay
Posted 24 March 2020 - 07:34 AM
These are the discs with the slots I was referring to. Anyone identify these? They are fitted to a modified HR front end and believed to be from a Torana.945d8b4335d57a6b76e2b43ee0afaa23.jpg
#11 yel327
  • 13,790 posts
Posted 24 March 2020 - 07:59 AM
Look very much like LH-UC or 4cyl Commodore to me.
#12 UCSLE
UCSLE
  • 728 posts
  • Name:troy
  • Car:Goggomobil
Posted 24 March 2020 - 04:34 PM
Clay check the nut that holds the rotor on , small nut will be HR stub and large nut will be LC/UC stub .
most likely be that they are LC/UC stubs with that rotor
#13 claysummers
claysummers
  • 3,716 posts
  • Name:Clay
Posted 24 March 2020 - 08:06 PM
Thanks Troy,
The photo was picked from Gumtree. The rotor is definitely not HD HR. I regularly see this style of rotor fitted to HR balljoint front ends and I’m curious as to what car they originate from. I do believe they can be bolted up with matching calipers to HR stubs, with resultant track increase. The difference in king pin inclination between Torana and Holden means that correct camber can’t be set when Torana assemblies are fitted to Holden HD to WB balljoint front ends.
Handy to know about the castellated nut size in differentiating stub axles.
Clay
#14 _LONA-CK_
_LONA-CK_
Posted 25 March 2020 - 05:49 PM
1973 LJ
Cheers gong
#15 RallyRed
  • 8,213 posts
Posted 25 March 2020 - 09:05 PM
Thanks all.
1973 LJ
Cheers gong
73 you say John...how so ?
#16 claysummers
claysummers
  • 3,716 posts
  • Name:Clay
Posted 25 March 2020 - 09:15 PM
1973 LJ
Cheers gong
Thanks gong
Clay
#17 _LONA-CK_
_LONA-CK_
Posted 26 March 2020 - 07:30 AM
RallyRed Col my answer was to your question, sorry clay if I got you confused you disc looks to be UC
Cheers gong
#18 claysummers
claysummers
  • 3,716 posts
  • Name:Clay
Posted 26 March 2020 - 08:24 AM
Cheers gong
ok that confirms yel
