Clutch Linkage Question.
15 replies to this topic
#1 Indy Orange
Indy Orange
  • 2,848 posts
  • Name:Paul
Posted 15 March 2020 - 04:18 PM
Hi all ,someone looks to have shortened the clutch rod linkage and welded .Could someone be kind enough to let me know overall length measurement ? Regards Paul.
#2 DMLC71
DMLC71
  • 424 posts
  • Name:Daz M
  • Car:1971 LC 4 door
Posted 15 March 2020 - 05:43 PM
I’m my experience the clutch brackets never weld too well. They end up breaking.
#3 Indy Orange
Indy Orange
  • 2,848 posts
  • Name:Paul
Posted 15 March 2020 - 06:09 PM
This ones been welded since I've had it many years, although I think it's been shortened (not by me).I'd like to keep it original.I figure if I weld a few elongated holes up and repair worn pins , there's no reason it shouldn't work as it should.
Edited by Indy Orange, 15 March 2020 - 06:15 PM.
#4 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 15 March 2020 - 06:41 PM
Shitest design ever in any holden, looked like something of a model t or a tractor.
#5 Indy Orange
Indy Orange
  • 2,848 posts
  • Name:Paul
Posted 15 March 2020 - 07:44 PM
Yeah I'll second that!
Still need to know the overall length though.
#6 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 15 March 2020 - 09:23 PM
Put up a photo of which bit you want an exact measurement of & i will see if i can measure 1 for you mate, i have 1 to do some work on.
#7 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,289 posts
  • Car:ɐuɐɹoʇ
Posted 15 March 2020 - 10:36 PM
Hi
Bazza
#8 Indy Orange
Indy Orange
  • 2,848 posts
  • Name:Paul
Posted 15 March 2020 - 11:25 PM
Thanks Baz ,legend!
#9 MFM
MFM
  • 687 posts
  • Name:Mark
  • Car:xu1
Posted 16 March 2020 - 07:59 PM
Paul I have a well used one and appears to be 3" although mine has 'play' in the shaft but if you are just after the overall length then 3" according to my ruler.
#10 MFM
MFM
  • 687 posts
  • Name:Mark
  • Car:xu1
Posted 16 March 2020 - 08:03 PM
This is a better overall photo
#11 u1 71
u1 71
  • 467 posts
  • Name:peter
  • Car:torana
Posted 16 March 2020 - 08:35 PM
rare spares used to sell those relay levers if you can't get one try John gong
Edited by u1 71, 16 March 2020 - 08:38 PM.
#12 MFM
MFM
  • 687 posts
  • Name:Mark
  • Car:xu1
Posted 16 March 2020 - 09:05 PM
My linkage looks visibly different to the one Bazza has posted, so perhaps the linkages changed over the years?
#13 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,289 posts
  • Car:ɐuɐɹoʇ
Posted 16 March 2020 - 09:53 PM
Hi
Looking at mine now - it appears to have been modified so that the rotating part that connects to the clutch pull rod is detachable. The parts catalogue shows those 2 segments as one assembly.
That would suggest Mark, that yours is the original assembly. That drastic wear on the pivot posts is typical of the rat trap mechanism. I just discovered the same phenomenon in my pedal box when the pull rod connects to the clutch pedal. The post was hanging by a thread, glad I took the opportunity to inspect it..
Bazza
#14 S pack
  • 15,538 posts
Posted 16 March 2020 - 10:09 PM
Mine is the same as Mark's.
#15 S pack
  • 15,538 posts
Posted 16 March 2020 - 10:16 PM
Bazza, the anchor on your Torana relay lever looks to be the type used on the HK,T,G relay lever, it has a double thickness shank. Part No. 2809745
The part number for the anchor that attaches to the Torana 6cyl RHD clutch pedal is 7433839. See Group 0.787 in the parts catalogues.
This anchor is also used on the LC, LJ relay lever and the HK,T,G clutch pedal.
Edited by S pack, 16 March 2020 - 10:17 PM.
#16 Indy Orange
Indy Orange
  • 2,848 posts
  • Name:Paul
Posted 16 March 2020 - 11:47 PM
Thanks guys ,much appreciated.
