Hi all. Drove the ute for the first time in two weeks and the indicators have stopped flashing. The lights simply come on and stay on until the stalk resets. The hazard lights work fine and all lights work. So, given I have limited knowledge in this area, before I go pulling things apart, can I get a best guess as to what the likely issue is. I'm assuming the flasher (if it's separate to the hazard lights flasher) or the fuse is the issue but how would I know. Thanks in advance. Cheers Ron
WB ute indicator issue help needed
Posted 17 March 2020 - 03:58 PM
Posted 17 March 2020 - 04:10 PM
It needs a new flasher relay. It is a separate unit to the hazard flasher relay.
If it was a fuse, the blinkers wouldn't light up.
Dr Terry
Posted 17 March 2020 - 06:27 PM
Thanks Dr Terry. Was hoping that was the case. Now to find and replace. Wish me luck lol. Cheers Ron
Posted 18 March 2020 - 09:29 AM
Something new learnt today. Thank you Dr Terry once again.
Posted 29 March 2020 - 12:17 PM
Probably won't surprise anyone but I now recall the auto elec. putting a new can in (Narva) when I had him go over all the wiring. That was just over 2 years ago. Today I finally found the original can which is a bit beat up, but swapped it over and all working fine. Thanks again gents. Cheers Ron
