Toyota 5 speed
4 replies to this topic
#1 Rana101
Rana101
  • 45 posts
  • Name:Derek
  • Car:Lh
Posted 21 March 2020 - 06:21 AM
Good morning all
    Have option to buy 5 speed Toyota box with Holden 6 bell housing
  Numbers on box are 33141-20090 and 33111-20091
   Any ideas on what it is worth ? Is in good running order
   Don’t want to pay to much and also don’t want to rip guy off
   Thanks in advance
    Derek
#2 dattoman
  • 16,461 posts
Posted 21 March 2020 - 10:17 AM
Likely steel case W50
Depends on condition
Unknown its probably $200
Fully recon would be closer to $1000
Make sure it comes with fork , bearing carrier , shifter and output yolk for tailshaft
https://www.rollaclu...eries/Gearboxes
Attached File  w50.jpg   88.58K   6 downloads
#3 jd lj
jd lj
  • 2,099 posts
  • Name:James D
  • Car:LJ SVO
Posted 21 March 2020 - 10:28 AM
It also depends on the shifter position. The gearbox pictured above has the correct shifter housing to match the Aussie 4 speed gearboxes. Some are positioned further back but are interchangeable with the correct one but you have to open the box up to do it.
#4 claysummers
claysummers
  • 3,273 posts
  • Name:Clay
Posted 21 March 2020 - 12:38 PM
If so, they were said to be very strong box and better fit to pre-HD Holden cars than the M15 M20. Long in the tooth now though. Don’t buy unless you get good bell housing and clutch actuation I would say.
#5 rexy
rexy
  • 3,579 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 21 March 2020 - 01:31 PM
And get the gearbox crossmember mount too.
Nice shift feel with that box.
