Hi all. I hope you are all safe and well . My question is i am putting the loom back in the car . I am testing everything as i go. i have not connected the headlights or the wiper motor . I have the head light switch connected indicator stork connected when i pull the light switch on the dash lights dont come on and when i put the indicators on the can doesn't flash. I have checked all the fuses there seems to have power going to the headlight switch and stork but nothing seems to work. Thanks Gary.
uc wiring
Posted 05 April 2020 - 06:57 PM
Posted 05 April 2020 - 07:48 PM
Posted 05 April 2020 - 09:07 PM
Thanks hanra just as i thought nothing will work unless all is connected. Thanks Gary.
Posted 05 April 2020 - 10:21 PM
Do the headlights actually come on? Try turning the headlight switch knob as this acts as a dimmer for dash lights.
Posted 06 April 2020 - 12:00 PM
Hi all yes i did turn the knob nothing as i say rodomo nothing is connected no headlights indicators wiper motor there is power going to the headlight switch but no where else it doesn't help when i dont have a uc diagram to go by. I have look for a diagram but could not find a color coded one. Thanks Gary.
Posted 07 April 2020 - 12:53 PM
Thanks Eunuch just what i needed. Thanks Gary.
Posted 07 April 2020 - 05:44 PM
Posted 02 July 2020 - 11:29 PM
Any Luck?
Had a similar issue with mine (I think) dash lights/parkbrake\brake light weren't coming on. Console light above radio was coming on and dimming as I turned the headlight knob. Turns out the plug points on the copper light board on the rear of the dash cluster had broken. Quick solder job to fix.
Posted 03 July 2020 - 05:11 PM
No it is still giving me a hard time. I have been doing other things but will be having another go at it soon . Thanks Gary.
#11 _SRH11_
Posted 11 July 2020 - 01:41 PM
Hi, I have just posted some updated info on the PINNED – “UC wiring diagram” post, that might help you out.
