This is awesome thanks for posting, I have just bought a pack of the same rods and was going to try this next. Could you add a photo of the tip you used? Are your rods the 2mm diamter ones?
Rods are 3.2mm as stated in instructions above. The tip I used with the best result is on the right. No luck with the soldering iron style. I’ll try using hardie flex as a base next time. The finer the torch flame the better I think. It’s a fine line between too hot and not hot enough. Cleanliness is the key. Even the file you use must be clean or use stainless steel wire brush.
Marty
