UC Torana Thermostat housing
17 replies to this topic
#1 DMLC71
DMLC71
  • 424 posts
  • Name:Daz M
  • Car:1971 LC 4 door
Posted 18 April 2020 - 01:35 PM
Hi Guys
i’m after the anti pollution fitting that goes in the top of the thermostat housing.
I need the complete fitting so I can run the hose from the canister and return to the manifold
thanks in advance
Dazm
#2 Dr Terry
Dr Terry
  • 3,276 posts
Posted 18 April 2020 - 04:01 PM
The vacuum temperature switch on top of the thermostat switches the vacuum advance line to the distributor, it has nothing to do with the carbon canister.
Dr Terry
#3 DMLC71
DMLC71
  • 424 posts
  • Name:Daz M
Posted 18 April 2020 - 04:55 PM
Thanks Dr Terry
if any body has one please contact me
#4 rodomo
  • 17,998 posts
Posted 18 April 2020 - 11:36 PM
Dr Terry
And if I recall correctly, was only on manuals? :huh:
#5 Peter UC
Peter UC
  • 765 posts
Posted 19 April 2020 - 08:06 PM
Nope mine was auto and had one, come to think of it the LX I had was auto and had one too
#6 liswar2
liswar2
  • 1,481 posts
  • Name:Wazza
Posted 19 April 2020 - 09:14 PM
I can take a photo tomorrow of mine and post it up for you so we can see what it looks like .
#7 liswar2
liswar2
  • 1,481 posts
  • Name:Wazza
Posted 20 April 2020 - 04:40 PM
Our UC hatch has 2 switches, 1 on top to carby and manifold, and dizzy,
1 at the front to ecg and carb,
1979 sunbird hatch....
Hope this helps
#8 rodomo
  • 17,998 posts
Posted 20 April 2020 - 11:07 PM
Maybe 2 different switches for auto and manual? Dunno, forget, might have to look at old diagrams?
What I do remember is that switch (the big one on top of the thermostat housing) controlled vacuum advance on the manuals but only in top gear. The switch on the gearbox was an electric switch and there was another elect over vacuum switch???......mounted to the side of the rocker cover?
All from memory
#9 claysummers
claysummers
  • 3,321 posts
  • Name:Clay
Posted 21 April 2020 - 07:23 AM
My manual HX was vacuum advance in top gear only, controlled by the canister shaped switch on gearbox. This was overridden by the switch on the thermostat housing if the temperature got hot, so that the distributor got manifold vacuum, rather than ported vacuum, in all gears. Then another vacuum line drove the egr.
Absolutely horrible system. Throw that black spaghetti in the bin, or if you want it looking original, ball bearings were used to block it up. Rejet the carb. They were too lean from factory.
#10 rodomo
  • 17,998 posts
Posted 21 April 2020 - 11:46 PM
Yep, looked at the "she'll be right" manual today and it said both auto and manual.
There is still something in my brayn about pollution gear that only effected manuals?
Maybe I'm just getting old?
#11 claysummers
claysummers
  • 3,321 posts
  • Name:Clay
Posted 22 April 2020 - 08:03 AM
The auto has to be different as the shift lever switch will not know when gearbox is in top gear. Possibly it would allow ported vacuum when in drive.
#12 Westside Performance
  • 72 posts
  • Car:Hatch
Posted 26 April 2020 - 07:05 AM
I wonder if you could use one from a commodore? It looks the same as the type on the VB to VK series
I have a bog stock Starfire 4 here so let me know if any pics are needed
#13 rodomo
  • 17,998 posts
Posted 26 April 2020 - 02:56 PM
The plot thickens :huh:
#14 claysummers
claysummers
  • 3,321 posts
  • Name:Clay
Posted 26 April 2020 - 09:41 PM
Gregory predates Google and about as reliable. No, more reliable. Must have given mine away with the HX when I sold it. Sad day. Never sell.
#15 LHSL
LHSL
  • 995 posts
  • Name:Phillip
Posted 29 April 2020 - 04:31 PM
My christmas tree has a needle sticking out of the bottom stem. From the ones I have seen for sale etc not sure if this is correct.
Edited by LHSL, 29 April 2020 - 04:37 PM.
#16 rodomo
  • 17,998 posts
Posted 29 April 2020 - 10:57 PM
Your needle looks like a pop rivet stalk? I'm pretty sure the valve normally faces the other way too?
I dunno Maz? Maybe the auto had the valve on the T Stat housing but not on the trans?
I've still got this memory of man had something that auto didn't?
LHSL...……..is your car manual?
Edited by rodomo, 29 April 2020 - 10:59 PM.
#17 LHSL
LHSL
  • 995 posts
  • Name:Phillip
Posted 30 April 2020 - 07:26 AM
Rodomo no auto. The way it is facing was from factory. The needle is sharp maybe someone shoved it in to block the hole? Who the hell knows.
Edited by LHSL, 30 April 2020 - 07:26 AM.
#18 LHSL
LHSL
  • 995 posts
  • Name:Phillip
Posted 30 April 2020 - 11:20 AM
Apologies just reviewed my photos it is the wrong way.
