Hoses to Heater Core
3 replies to this topic
#1 Cook
Cook
  • 1,502 posts
Posted 24 April 2020 - 02:01 PM
Hi all.  As far as I can ascertain it doesn't matter which way around the lines are run in and out of the heater core.  I understand I need to get the lines right form the motor to the shut off valve etc but want to double check on the internal side.  Also is there a preference.  I saw someone suggesting running inward line to the top and out through bottom as a preference?  FWIW here is a pic of the heater core outlets.  It's an Old Air system.  Cheers Ron.
Edited by Cook, 24 April 2020 - 02:02 PM.
#2 Dr Terry
Dr Terry
  • 3,276 posts
Posted 24 April 2020 - 02:09 PM
If you run the inward hose to the lower fitting, it will self bleed. Valve on the inward hose also.
Dr Terry
#3 Cook
Cook
  • 1,502 posts
Posted 24 April 2020 - 02:29 PM
Thank you again.  Just one of the many times that you guys have pointed me in the right direction.  Cheers Ron
#4 claysummers
claysummers
  • 3,319 posts
  • Name:Clay
Posted 24 April 2020 - 09:19 PM
Convection will also aid flow if you plumb inlet to the bottom.
