F100 9inch into LC
Posted 26 April 2020 - 04:15 PM
Posted 27 April 2020 - 03:27 PM
Yes it will once all the old brackets are removed and new torana brackets or mounts are welded in place,housing generally get straighted,.F100 use bigger bearing so who is ever is doing your diff will sort that for you,.perhaps with new axles,..the centre if later will more likely be 31 spline which is good and stronger than your standard 28 spline..hope this answer your question..
Posted 28 April 2020 - 05:11 PM
I didn't mind as it helps launches same as lowering front hole on body. Not good for corners though.
I would imagine LC could likely have the same issue.
Edited by Toranamat69, 28 April 2020 - 05:13 PM.
Posted 29 April 2020 - 10:28 AM
First question would be, do you really need a 9 inch?
Have seen lots of them fitted to the little Toranas over the years, so it is possible.
These days, the BW78 is enough for most cars that are road registered.
The added weight of the 9 inch can make the car slower compared to using a BW.
BW are capable of taking 500hp. Thats a lot of mumbo for a road car, especially something as light as an LC or LJ.
Rob
Posted 08 May 2020 - 03:45 PM
