Axle balance ?
4 replies to this topic
#1 biga064
biga064
  • 195 posts
  • Name:Adam
  • Car:EH Holden
Posted 30 April 2020 - 05:15 PM
Hi can anybody tell me are  axles Banjo borg warner etc  Balanced ?? ta
#2 76lxhatch
  • 7,151 posts
Posted 30 April 2020 - 05:38 PM
Generally, no. You can have issues with runout or bent axles causing vibrations though if that's what you're chasing.
#3 biga064
biga064
  • 195 posts
  • Name:Adam
  • Car:EH Holden
Posted 30 April 2020 - 06:04 PM
Thanks some of the axles have several holes in them of different sizes so I thought they might be balance holes ??
#4 76lxhatch
  • 7,151 posts
Posted 30 April 2020 - 06:39 PM
For accessing the retaining bolts and other bits behind the flange
#5 Bigfella237
  • 4,369 posts
Posted 01 May 2020 - 10:11 AM
A lot of the old brake drums you see have balance weights on them, but I can't recall ever seeing a disc rotor with weights?
That was a problem with earlier Commodores, they were on-car balanced at the factory, but later when the tyres were changed, the tyre shop balanced the wheels off the car, so if there was any imbalance in the axle/hub/rotor assy it was no longer compensated for and all of a sudden you had a vibration.
You could do it by having a wheel perfectly balanced off the car, then bolting it on the axle and doing an on-car balance to see if anything changes. You would obviously need to take weight off the hub/axle flange on the opposite side to where the balancer is saying to add weight to the wheel, which could be a prick of a job depending on how far out of balance it is?
The better way would be to find a good machine shop, especially one that does custom driveshafts, they should be able to run your axles up in their machine and balance them for you, provided they don't have to much run-out of course (if they did you may well chew out the wheel bearings prematurely anyway).
Edited by Bigfella237, 01 May 2020 - 10:12 AM.
